Radiator Fin simulation with porous media
Old   July 31, 2013, 04:41
Default Radiator Fin simulation with porous media
Kadir Gökhan GÜLER
Kadirgg is on a distinguished road
Hello everyone,
I'm trying to simulate a vehicle radiator fin by using porous media. First i simulated the single fin with a cosiderably fine mesh under different reynolds numbers. I curve fitted 2nd order polinomial on to the deltap vs velocity data and i extracted the viscous and inertial coefficients by using darcy-forchhiemmer equation.
After simulating real fin i post process pressure drop across real fin by subtracting average inlet pressure from the fin inlet and outlet. When i simulated same fin simulation by just changing fin domain with porous domain and implementing the viscous and inertial coefficients that have found, pressure drop values doesn't match.
Could anyone please help me? Could you please share your experiences with me? This is very important for me for completing my master's thesis.
Thanks.....
Kadirgg is offline   Reply With Quote
Old   July 31, 2013, 12:02
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi Kadirgg,
Take into account that you have always to manage simulation error, even if the mesh and your model are very accurate.
So I can just suggest to build Darcy-Forchheimer function with experimental data if possible: I fitted the curve (measured pressure drop and flow rate) of a burner some months ago and, when I put the coefficients in Fluent, the porous media was simulated quite well.
Try it!
Sorry for my bad english
Kind Regards
Bionico
Bionico is offline   Reply With Quote
transient Simulation with porous media Chrisi1984 OpenFOAM Running, Solving & CFD 6 August 26, 2015 17:13
Porous Media Simulation with CFX/Fluent Ghasem ANSYS 1 May 14, 2013 10:07
compressible flow through porous media Chirag2302 FLUENT 0 March 3, 2012 00:13
asking help for porous media simulation jim23keda FLUENT 0 July 29, 2010 10:21
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
