Species Transport Model
Old   July 30, 2013, 02:20
Default Species Transport Model
srinag is on a distinguished road
Hi, I've been trying to simulate reacting flow in a model combustor. Realizable k-e model is used for turbulence modeling and Finite rate eddy dissipation model is used for combustion. The constants such as the Prandtl & Schmid numbers are retained as default values. The temperature predicted is about 400K higher than the experimental results. Can anyone pl suggest me the modifications that could be done to obtain a lower temperature.
Thanks in advance.
srinag is offline   Reply With Quote
Old   August 1, 2013, 16:41
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Thanks in advance.
Hello
Why do you use finite rate model? In this case, turbulent flow is ignored, because finite rate model is used when the kinetic is reaction controlling. If the flow is turbulent, you should use finite rate/eddy dissipation rate model. In this case, if the kinetic is controlling, then, finite rate model is applied and on the other hand, when the turbulency is controlling, then eddy dissipation model is used. So I suppose that you should change the reaction model.
Regard yours
A CFD free user is offline   Reply With Quote
Old   October 6, 2013, 13:30
sofiane ouali
potion is on a distinguished road
hi!
see material panel in first and change default value
in second time, you can change cte A and B of Ahrenius law in reaction panel
potion is offline   Reply With Quote
Please help!! Patch and Species transport Julie FLUENT 5 August 3, 2016 04:10
Divergence problem for species transport model MY FLUENT 3 January 11, 2014 05:46
chemical reaction and species transport mohamad3564 FLUENT 0 June 11, 2012 04:58
Implement species transport equation Tobi OpenFOAM Programming & Development 0 June 2, 2012 14:26
species transport model or mixture model? achaokaoyan Main CFD Forum 0 July 10, 2010 11:52
