About periodic boundary condition.
Old   July 29, 2013, 04:19
Post About periodic boundary condition.
Ilias
kohel_11 is on a distinguished road
Could any one please give me the answer of the follwing question? What is mean by upstream bulk temperature at periodic condistions? If temperature is changing with respect to time in my periodic boundary, can I use periodic boundary condition? And what will be the value of upstream Bulk Temperature when temperature vary along the periodic boundary with respec to time?
Adavance thanks
kohel_11 is offline   Reply With Quote
Old   July 29, 2013, 06:08
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
There are several methods known in literature to handle periodic heat transfer calculations, the main fact being that it is probably a not really well posed problem. However, the basics in Fluent is that, for a periodic heat transfer calculation, unless nothing interesting happens in your domain, some temperature difference will arise between your inlet and outlet periodic faces.
So the problem is, how can Fluent manage the fact that from one time step (iteration) to the next the temperature will keep changing (for fixed heat flux boundary conditions) or converging toward a constant temperature (for fixed wall temperature)? The method adopted in Fluent is based on the fact that, for the two conditions above, the overall jump (between the periodic faces) in the bulk temperature can be somehow computed; as a consequence it is just subtracted before mapping the temperature from the outlet to the inlet. The way it is actually done is by modifying the coefficients coupling the cells adjacent to the periodic faces, so that it is not anymore a straight periodic condition but a scaled version.
In order for this method to work, the reference bulk temperature at inlet is required. This is just the mean temperature (or something similar) and will not actually affect your computation besides setting a reference value for the temperature in the domain (indeed you are not allowed, for periodic heat transfer computations, to have temperature dependent coefficients).
Hence the periodic condition will give you the same spatial pattern for the temperature on the two faces, just that one is scaled with respect to the other.
Is this method time accurate? I don't know but i don't think so. Is it possible to have the bulk temperature specified at each time step: I don't know but i don't think so.
sbaffini is offline   Reply With Quote
Old   July 29, 2013, 22:18
Ilias
Thanks sbaffini. I am sloving for transient case and also mean temperature or free stream bulk temperature is changing with respect to time. I dont have any idea how to put bulk temp at every time step. I dont think so it is practicable.
My question is : Since its changing with respect to time, so that my assumption never be accurate. Now if my assumption is wrong, how they are going to effect my result or can I neglect this error?
Advance thanks...
Old   July 30, 2013, 08:37
sbaffini's Avatar
Paolo Lampitella
At this point, i would like to ask you what are you exactly trying to model as there might be more options to handle your specific case. Can you give some additional details?
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Problem with a periodic boundary condition chuck209 CFX 10 May 9, 2012 17:15
translational periodic boundary condition Rola Afify FLUENT 2 September 12, 2006 09:39
