Grid interface between zones of different size |
July 24, 2013, 09:04 |
Agustín Villa
Rep Power: 15 |
Hi!
I'll explain you why I'm doing, to help you to understand my trouble. I have to simulate a duct , in whose interior I have twisted tapes (which separates the fluid at two). At the outer side, I have to put an element, which have a uniform heat flux at its upper side. It emulates a weld between the duct and other element, which doesn't matter. So, I have these choices:
Because of the first one gives troubles (one of the fluid zones gets warm but the other rests cold), and the third one gives a little temperature error at the boundary layer between the fluid and the duct (not a problem, it could be due to the models, etc...), but I want to try the second one, to try to get out the previous error. My doubt is if when I create the grid interface in Fluent between the outer side of the ducth, with the little element above the duct, the grid interface will link all the outer side of the duct, or just the covered part by the weld? As you can see, at this option, I can't create a face where I put the weld face I wait your answers! |
July 24, 2013, 09:44 |
Alex
Rep Power: 49 |
Some sketches might help us understanding the problem.
July 24, 2013, 10:21 |
Agustín Villa
Rep Power: 15 |
Here I attach the cross section of the problem. The upper element is the weld, and you can see the duct and the inner side, with the tape.
grid interface, twisted tape |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
exists minimum grid size for Ansys calculation? | sooh2121 | ANSYS | 2 | March 7, 2012 11:34 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 03:53 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
periodic grid interface | santosh | FLUENT | 3 | August 30, 2001 11:06 |
