Modeling transient negative pressure (suction pressure) in outlet
Old   July 18, 2013, 15:18
Default Modeling transient negative pressure (suction pressure) in outlet
N_mrtz is on a distinguished road
I am new in fluent. I a modeling the two branches system of pipes with two inlets and one outlet. The sucking pressure(negative pressure) is applied in outlet to force the fluid to flow from inlet. This pressure is transient and varies by time. Also, it is important to have a constant mass flow rate which is known form outside. Both inside have the same condition. The system is incompressible.
I have some question related to boundary condition:
I applied mass flow rate for inlet (we have to get constant mass flow rate from outlet, so I divided this constant number by two, because we have two inlets and put it as mass flow inlet for each inlets)
Also, I assigned the pressure outlet which is the profile(user defined profile) as a function of time.
As I read in fluent articles, the mass flow inlet is more for compressible flow, so should I change it to any other boundary? I do not have any other information for inlet.
Also, for pressure outlet, I have profile of pressure, (not equation), I mean that I have the values of pressure versus time. I got these values from experimental results. These values are negative, should I apply the negative value on the profile or I have to change it to the positive value?
I appreciate if you can help me.
N_mrtz is offline   Reply With Quote
Old   July 18, 2013, 21:59
blackmask will become famous soon enough
For incompressible flow, the pressure difference matters so that you do not have to change the negative values into positive ones. You could use the velocity inlet b.c. instead of mass flow because the former is more robust. May I ask what is the purpose of your simulation? To find the pressure at the inlet?
blackmask is offline   Reply With Quote
pressure inlet & outlet. help ASAP Plz engahmed Main CFD Forum 0 June 13, 2010 16:34
Help ASAP! pressure inlet & outlet engahmed FLUENT 0 June 13, 2010 16:33
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
