solution is not getting converged
Old   July 16, 2013, 04:10
Default solution is not getting converged
Nijanthan Thinakaran
Nijanthan is on a distinguished road
am having pressure inlet of 83 bar,where its inlet diameter is of 9.05mm. also pressure outlet of 43 bar with outlet dia of 2.05mm.
my problem is if i monitor the mass flow rate in inlet it is around e15. because of which my solution is getting diverged and also am having turbulence viscosity limited error. how do i rectify it ???
Note: msh count is of 6.4million and it has interfaces in it.
Nijanthan is offline   Reply With Quote
Old   July 22, 2013, 09:40
Paritosh Vasava
vasava will become famous soon enough
83 bar (almost 38 atm) and a diameter of mere 9 mm looks an unrealistic problem. What is the application of your problem?
vasava is offline   Reply With Quote
Old   July 24, 2013, 05:52
Default injector
well its kind of water injector. sorry sir cant tel rest of it coz its confidential
Old   July 24, 2013, 08:37
Paritosh Vasava
Ofcourse with that high pressure you would get high mass flow rate. The turbulence viscosity error is because of coarse mesh, bigger time step or both.
Old   July 24, 2013, 21:35
upeksa is on a distinguished road
I'm not sure, but I think that the problem could be that the conditions of pressure-inlet and pressure outlet, it might be too restrictive.
First try with mass-flow-inlet and presure outlet and if it doesn't still work, try mass-flow-inlet and outflow.
Also use the first order discretization and make sure you have set up your case properly, specially make sure your material choice is the correct one.
Best regards.
upeksa is offline   Reply With Quote
Old   July 25, 2013, 02:42
Paritosh Vasava
Still my concern is the enormous amount of pressure and the tiny little outlet. You would need billions of mesh elements just to keep the courant number low.
There must be some other detail you can spare.
simple solution converged in 9 iterations? Gabbee90 OpenFOAM Running, Solving & CFD 4 January 29, 2019 22:04
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 13:44
New sixDoFRigidBody BC working with laplaceFaceDecomposition Ya_Squall2010 OpenFOAM Running, Solving & CFD 13 April 17, 2013 03:04
residual plot after solution reset plaunie STAR-CCM+ 1 April 3, 2010 07:53
Does FOAM converge to exact solution in Laplace equation? santiagomarquezd OpenFOAM Running, Solving & CFD 0 March 26, 2010 08:52
