Basic Question about Sliding mesh
Old   July 16, 2013, 02:56
Exclamation Basic Question about Sliding mesh
Nara Shikamaru
shikamaru is on a distinguished road
I want to know something very basic about sliding mesh.
As shown in the picture, if I have a solid zone with sliding mesh on top of a fluid zone, what will be the momentum boundary condition in the interface?
Will it be a No Slip wall? or it will have no effect on the flow? in that case what is boundary condition for momentum in the fluid side of the interface? ( Given that I declared the interface between two zones as a coupled wall while creating the interface.)
shikamaru is offline   Reply With Quote
Old   July 22, 2013, 09:43
Paritosh Vasava
vasava will become famous soon enough
There is no need to declare momentum boundary condition for the interface. Fluent will take care of it.
vasava is offline   Reply With Quote
Old   July 22, 2013, 16:30
Nara Shikamaru
My knowledge so far on this:
The momentum boundary will be a zero velocity wall on each time step. So, basically the movement of the top part will have no effect on the fluid flow and will act just as an stationary wall when the interfaced is declared as a "Coupled wall". However, you will have a new wall and wall-shadow in your boundary which you can apply moving wall boundary condition.
If I had temperature that will pass through as heat flux which fluent will calculate using "virtual polygon approach" (which only appears in all the available fluent manuals one time only without any reference what so ever)
sliding mesh
Question on moving mesh, mesh velocity is really small! ripperjack Main CFD Forum 2 April 28, 2014 14:37
sliding mesh for valves & sonicTurbDyMEngineFoam sasanghomi OpenFOAM 9 March 28, 2013 11:22
Sliding mesh and Momentum Theory Lam FLUENT 2 February 21, 2013 17:08
what does sliding mesh REALLY mean? Jason FLUENT 2 February 21, 2012 06:49
Sliding Mesh Sridhar FLUENT 0 August 23, 2002 15:54
