Enhanced wall Treatment
Old   July 13, 2013, 11:58
Default Enhanced wall Treatment
Luca
marluc is on a distinguished road
I have a question regarding the EWT used in FLUENT.
A two-layer approach is used. The domain is subdivided into a viscosity affected region and an outer region depending on the turbulent Reynolds number (Re_y* = 200; above this value outer region).
If Re_y<Re_y*, epsilon is analitically determined, while momentum and k transport equations are retained and solved.
The previous subdivision does only apply for the evaluation of epsilon and turbulent viscosity? The velocity is analitically evaluated in the entire viscosity affected region or only in the FIRST near wall cells, as I guess?
Moreover, for the k-omega (standard and SST) the value for omega is only imposed at the FIRST near wall cell while all other quantities are calculated by solving the transprt equations? (except the velocity, which is analitically evaluated at the first wall cell)
marluc is offline   Reply With Quote
Does realizable k-e model with enhanced wall treatment work for surface roughness? zyy95900 FLUENT 5 November 15, 2017 17:13
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 06:56
Applying enhanced wall treatment in free slip wall amarjogot FLUENT 1 June 26, 2013 13:44
Enhanced wall treatment with user-defined mu_t tstorm FLUENT 0 August 20, 2009 14:05
LES wall treatment Valerio FLUENT 0 April 26, 2008 08:12
