How to do Enthalpy porosity formulation in fluent |
July 12, 2013, 07:43 |
Vjoess
Rep Power: 14 |
I want to have enthalpy porosity formulation for my case. How do i ensure that in fluent. How can i define this in fluent.
The above formulation is required for liquid fraction estimation of phase change material. I dont have much idea about it. Kindly suggest how to implement it in fluent. I am using solidification/melting solver for my problem |
July 13, 2013, 02:44 |
Yash Ganatra
Rep Power: 13 |
The Solidificatio Model in FLUENT uses the same method only
August 30, 2013, 06:26 |
Vjoess
Rep Power: 14 |
Do i have to use multiphase or species transport for my case. My case is to melt a WAX enclosed in a cylinder using water which passes through the centre of the cylinder without direct contact. Also plz tell me if turbulence model needs to be activated if my water flow velocity is 0.5 m/s through pipe having dia 0.054m. though the rey no is turbulent but is it worth using a turbulence model when i am interestd in seeing the melt fraction and the countours of temperature of the wax. |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Re: UDF for Modelling Soldification using Enthalpy Porosity Technique | yashganatra | Fluent UDF and Scheme Programming | 1 | October 30, 2014 05:43 |
Error in reading Fluent 13 case file in fluent 12 | apurv | FLUENT | 2 | July 12, 2013 08:46 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 12:55 |
Enthalpy Calculation In fluent | Naher | FLUENT | 0 | June 14, 2011 03:39 |
