Volume Flow Rate and Area * Velocity values different
Old   July 9, 2013, 01:55
Default Volume Flow Rate and Area * Velocity values different
Narendra Gadwal
narendra.gadwal is on a distinguished road
Send a message via Yahoo to narendra.gadwal Send a message via Skype™ to narendra.gadwal
I have a fluent model, where the fluid is of constant density.
Structured mesh, well converged.
But the volume flow rate what fluent shows is different when I multiply the area and area weighted average of velocity magnitude.
Did not understand ? Why ?
(Volume Flow Rate) Fluent != (Area) fluent * (Area weighted average of velocity magnitude) fluent
Thanks in advance
narendra.gadwal is offline   Reply With Quote
Old   July 10, 2013, 04:41
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Is it multiphase?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   July 10, 2013, 05:41
Narendra Gadwal
No .... the fluid is air
Old   July 10, 2013, 05:46
Philipp
That sounds strange... How much do they differ?
Old   July 10, 2013, 05:49
Philipp
Ahh maybe this:
What do you integrate for the "Area weighted average of velocity magnitude"? You need to integrate only the perpendicular (to the surface) component of the velocity vector - not the length of the complete velocity vector!
Old   July 10, 2013, 05:54
blackmask will become famous soon enough
(Volume Flow Rate) Fluent == (Area) fluent * (Area weighted average of normal component of velocity) fluent
Note the difference between <vector u> dot <vector A> and |magnitude u|*|magnitude A|.
blackmask is offline   Reply With Quote
Narendra Gadwal
I tried with Velocity magnitude, X, Y and Z velocities .... still they differ.
When I calculate velocity = (volume flow rate/area) fluent and
area weighted avg of (velocity magnitude/X-vel/Y-vel/Z-vel), both differ by almost 4-5m/s
Old   July 10, 2013, 05:57
Philipp
But this isn't what I wrote:
You need the perpendicular velocity component. If your surface is no "simple" cartesian surface, the cartesian (x,y,z) components won't help you.
What you need is "A dot v"!
Old   July 10, 2013, 06:10
Narendra Gadwal
It is a simple rectangular surface. So don't you think the velocity magnitude is normal to that ?
Old   July 10, 2013, 06:12
Philipp
Not necessarily... Why don't you post pictures?
Old   July 10, 2013, 06:29
Let the normal of the rectangle be [nx, ny, nz], and the area-weighted average of x-,y-,z- velocity be [U, V, W], then (U*nx + V*ny + W*nz) should not be differ much from the volumetric flow rate divided by the area.
Old   July 10, 2013, 12:27
Narendra Gadwal
Thanks !
Will do that.
Old   January 23, 2022, 18:24
mz_uon is on a distinguished road
Hi
I am stuck with the same problem now.
See attached the image of my model. I am trying to calculate the volume flow through this room. But the 2 methods are giving different answers. I am not sure if I understand it correctly.
Any suggestion/help?
Thanks
mz_uon is offline   Reply With Quote
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 22:02
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Finding volume flow rate through a car wh88 FLUENT 0 September 23, 2011 15:12
Constant flow rate through a small area inside the fluid domain. robingilbert OpenFOAM 7 October 4, 2010 17:19
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
