Inlet turbulence conditions from given data
Old   July 8, 2013, 10:13
Default Inlet turbulence conditions from given data
siw
Stuart
siw will become famous soon enough
When using the Spalart-Allmaras turbulence model in a RANS simulation the User Guide (Fluent version 14.5 User Guide section 6.3.2.1.1) says that the turbulent viscosity or turbulent viscosity ratio should be chosen.
I'm conducting a simulation of the experimental flow over a wall-mounted series of bodies as reported in the paper by Martinuzzi and Havel (ref 1). In this paper it gives the following information with regards to the inlet turbulence data: 1) the measured turbulence level was less than 1.5% and 2) the freestream flow was uniform within 0.5%.
Given that data what's the best way to set up the inlet turbulence conditions in Fluent? Could a turbulent viscosity or turbulent viscosity ratio be estimated from the above data? Or should the intensity (=1.5%) and a turbulent length scale (equal to the size of the body since eddies will not be larger than that) be used?
Thanks.
Reference 1. Martinuzzi, R. J. and Havel, B. (2000), Turbulent Flow Around Two Interfering Surface-Mounted Cubic Obstacles in Tandem Arrangement, J. of Fluids Eng., Vol. 122, p. 24-31.
siw is offline   Reply With Quote
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
inlet boundary conditions newOFuser OpenFOAM 1 January 10, 2013 09:08
Setting the inlet conditions for a scramjet combustor Scramjet2011 FLUENT 0 October 14, 2011 14:37
inlet boundary conditions mattia Main CFD Forum 0 February 11, 2009 07:06
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
