assign transient random data to inlet face
Old   July 24, 2013, 20:04
colopolo is on a distinguished road
Originally Posted by blackmask View Post
Add
#include <math.h>
after
#include <stdio.h>
I am still getting the same error (still library error).
In your system, If you didn't get any error, please kindly inform me your system environment sush as, os, version of visual studio, sdk etc..
it may relate platform problem? my system is win64.
colopolo is offline   Reply With Quote
Old   July 24, 2013, 21:08
blackmask will become famous soon enough
No, it is not a platform problem. The reason is that
lround
is not implemented in MSVC's math.h file.
Add the line
#define lround(x) (int)((x)+0.5)
after
#include "udf.h"
and try again.
Sorry for the inconvenience.
blackmask is offline   Reply With Quote
Old   July 24, 2013, 21:30
lround
Add the line
after
#include "udf.h"
and try again.
Great. Thanks Blackmask!!.
Finally I forward one step.
I defined velocity inlet as udf u_profile::libudf after load your code.
then I simply run it but the assigned velocity is zero at inlet surface.
Old   July 24, 2013, 21:49
lround
Add the line
after
#include "udf.h"
and try again.
After loading code, I defiend velocity inlet as udf u_profile::libudf at boundary condition.
Then simply run it but assigned velocity is zero at the inlet surface.
um.....
Old   July 24, 2013, 21:58
Attached file is a very simple test domain which has same coordinate of the input data.
could you check it if you have time?
Thanks in advance
Old   July 24, 2013, 23:13
You can not count everything on me. It is your job after all. The data file in the source code is "voutu.txt", as you mentioned in several posts before. The file name in the zip file is "voututen.dat". The input format specifier is
fscanf(fp, "%f,",...)
i.e., the data is separated by a comma, again, as you shown in some previous post. The data in the zip file is separated by space.
I am willing to help people and I understand that you want to make progress fast. But please spend sometime preparing yourself. It does not take long for you to understand the basics of c programming language.
Old   July 25, 2013, 00:02
sorry abou that. Meanwhile I modified a little bit and finally it works well!!
I reallly apprieciate your great support. Thanks.
I always thanks your help from the begining this thread.
I will let you know the result of test when i finish it.
Again, I am very thank you. God Bless YOU
Create an internal face aylalisa OpenFOAM Pre-Processing 1 June 19, 2013 13:02
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Inlet profile from 2D velocity and turbulence data Attesz OpenFOAM Pre-Processing 2 March 11, 2012 07:09
Map external data (heat flux in) on solid face jerry1977 CFX 2 January 31, 2012 14:32
Transient Inlet boundary condition - fully develop Omer CFX 3 November 28, 2006 17:22
