mass weighted average temperature along a curve
Old   July 3, 2013, 04:20
Default mass weighted average temperature along a curve
preetam
preetam69 is on a distinguished road
hi,
i am new to fluent and this is a basic question.
suppose there is a channel with pressure inlet and outlet boundary conditions,and it's walls are subjected to heat flux.
so,after the computation i can see the mass weighted average temperature of the fluid inside the channel at the outlet.but how can i see the mass weighted average temperature of the fluid along the channel(assuming inlet x=0 to x=l at exit,how bulk temperature varies).
is creating sections at discrete locations along the channel location is the only option?how can i get a continuous curve?
thnx
preetam69 is offline   Reply With Quote
Old   July 5, 2013, 03:48
Karthik Ramaswamy
kartrmswy is on a distinguished road
Hi preetam69,
You can get the profile you want by inserting a line (Surface>line/rake> coordinates) in the direction you want to observe the variation of your parameter.
For example, If I have a circular pipe and I want to observe a continuous variation of temperature radially, I need to insert a line along a diameter of the pipe. I then need to plot XY curves of temperature with the direction vector as 1 and the remaining directions 0 ( in the XY curve set up dialog box).
Edit: Since you want an axial variation, you need to insert a line along the axis with the endpoint coordinates specified. Note that the direction of variation should be set in the XY set up as well!
Alternatively, you can use Iso surfaces - check the fluent manual for help.
Hope this helped!
kartrmswy is offline   Reply With Quote
Mass Weighted Average GRAUPS OpenFOAM Post-Processing 8 March 16, 2021 15:41
Area weighted or mass weighted average SAM Main CFD Forum 31 April 30, 2018 05:12
PLOTING weighted average vs distance Vorch FLUENT 0 May 28, 2012 17:29
Temperature Average Danny FLUENT 0 May 3, 2005 06:47
Sequential calculation of Temperature and mass tra J.W.Ryu FLUENT 7 June 18, 2002 08:12
