June 30, 2013, 01:38 |
calculate species reaction rate
Anna johnson
Rep Power: 13 |
Hi
I am modeling combustion with non-premixed model. To calculate reaction heat release, i have to calculate species reaction rate. How can i calculate species-n reaction rate in Fluent? Thank you..... |
June 30, 2013, 22:13 |
Christopher Hershey
Rep Power: 14 |
Have you looked into using the turbulence-chemistry interaction in the species model?
I do not work with combustion problems, but I do work with reactions in Fluent. I activate the species transport model using an Arrhenius rate constant since that applies to me, but I know that in combustion there are turbulence effects that govern the reaction. It may be activated for the non-premixed case. Check the tutorial guide for "Modeling Species Transport and Gaseous Combustion" as it probably pertains to your problem. Post back if you have more questions. |
July 1, 2013, 14:10 |
hershey
Anna johnson
Rep Power: 13 |
hershey,
I am using non-premixed combustion model. To calculate reaction heat release i need to know reaction rate for any species. My problem is reporting the reaction rate for any species in different section of flow. Thank you |
Custom Reaction Rate with foamChemistryReader | ChrisA | OpenFOAM Programming & Development | 0 | May 21, 2013 22:28 |
UDF molar rate of creation/destruction of species | Michal | Fluent UDF and Scheme Programming | 1 | January 18, 2013 08:26 |
Reaction rate under multi phases | kongl1986 | Fluent UDF and Scheme Programming | 3 | September 7, 2012 09:43 |
methane steam reforming reaction rate... | yerem3 | FLUENT | 0 | August 30, 2010 10:43 |
Reaction Source Term in Steady Species transport equation | cfdvenkatesh | Main CFD Forum | 0 | August 19, 2010 10:28 |
