Angular Velocity of the particle
Old   June 28, 2013, 15:28
Default Angular Velocity of the particle
vagaikwa is on a distinguished road
I am using DPM model and trying to simulate flow of few particles through fluid. How do I know if my particles are having any angular velocity? And if not how can i impart angular velocity? I have enabled Saffman Lift but it is not generating any lift on my particles.
Thanks.
Varad.
vagaikwa is offline   Reply With Quote
Old   June 29, 2013, 06:52
Default Answer
sadjad.s's Avatar
sadjad
sadjad.s is on a distinguished road
Send a message via Yahoo to sadjad.s
Hi mate,
I am rather sure DPM can not see angular motion of particles.
You see, particles should be too small, hence angular velocity would be negligible.
About Saffman force, if particle and flow velocities become equal, which will be after a while, Saffman force is zero.
ICEM, CFX and Fluent expert
sadjad.s is offline   Reply With Quote
Old   June 29, 2013, 10:34
Thanks for your reply.
Yes that is what is exactly happening. The velocities of particle and fluid becomes equal after a while. So which model should I adopt if I want to simulate particulate flow and see the translational and angular velocity effects and lift on the particles too.
Old   June 29, 2013, 10:40
Default Answer
sadjad.s's Avatar
sadjad
To see that you need to model 6DoF (Dynamic mesh). But problem is that it fails when particles strike to each other.
Old   June 29, 2013, 10:46
I thought of using Dynamic mesh. But the issue is my particle diameter size to tube diameter size is 0.04. Also I have to simulate flow 8 particles and then go upto 100-200 particles.
Old   June 29, 2013, 10:52
Default Answer
sadjad.s's Avatar
sadjad
This is DPM limitation and you may have to neglect angular velocity.
Other problem is your rather big particles sizes. I mean particles with 4% size of characteristic length are rather big for Discrete Phase and can fully change flow pattern. You may switch to Eulerian method.
Sadjad,
Do u think I should still go for dynamic mesh?
Old   June 29, 2013, 10:56
Oh the size is big? I thought it is small. Because the references I am using they have the ratio of particle to tube diameter size higher than what I am trying to do. Thanks for your help brother.
Old   December 26, 2013, 03:09
Rodman
ldm273507 is on a distinguished road
Hi,friend. I want to simualte the movement of water droplet. If you konw how to control the velocity of the water droplet using the DPM model? I write an UDF about this, but it's incorrect, could you give me some suggestion?
#include "udf.h"
#include "dpm.h"
DEFINE_ADJUST(my_adjust,d)
Tracked_Particle *tp;
cell_t c=P_CELL(tp);
Thread *t=P_CELL_THREAD(tp);
Particle *p;
if(P_POS(p)[2]<14.8&&P_POS(p)[2]>=13.4)
begin_particle_cell_loop(p,c,t)
P_VEL(p)[2] = -0.2;
end_particle_cell_loop(p,c,t)
"Uninitialized varible ’tp' used" and "Uninitialized varible ’p' used" appears when I compile the UDF.
Thank you.
ldm273507 is offline   Reply With Quote
forced to sticking of soot particle kmgraju CFX 0 November 27, 2012 10:08
particle velocity profile mr3_player FLUENT 0 October 8, 2012 16:33
angular velocity learning_never_ends FLUENT 0 June 30, 2008 18:04
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 07:10
particle velocity and velocity profile HGG FLUENT 2 June 10, 2001 17:32
