benard cells
Old   June 19, 2013, 20:40
Default benard cells
kris pani
krisipanikou is on a distinguished road
I am simulating natural convection heat transfer in a vertical can witch contains liquid, but I can't see the bernard-cells as I expected.. Is this major problem??
krisipanikou is offline   Reply With Quote
Old   June 20, 2013, 03:34
Yash Ganatra
yashganatra is on a distinguished road
It depends on the Rayleigh number. What is your rayleigh number? Aspect ratio of the cavity? Post some more details. The critical Rayleigh number is 1708.
yashganatra is offline   Reply With Quote
Old   June 21, 2013, 06:33
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
It also depends on the Turbulence model you are using. I have no experience on this specific problem but i guess it might be difficult, if not impossible, to see them in a steady k_eps simulation.
sbaffini is offline   Reply With Quote
Old   June 21, 2013, 14:59
Yash Ganatra
I had done the simulation ; it's not easy to capture ; Could you explain how does it depend on the turbulent model?
I had done an unsteady state but first I had done the steady state and then proceeded to unsteady.
Thanks,
Yash
Old   June 21, 2013, 15:32
sbaffini's Avatar
Paolo Lampitella
Ok, i don't know the exact details of the phenomenon but, of course it depends on the viscosity and, of course, at some point, if you increase the temperature jump you're gonna get convection. So, what i was saing is that a given turbulent model may largely affect the viscosity and the overall system to the point that the instability is for much higher Rayleigh numbers, if any.
Of course there are people doing it (unsteady of course):
http://www.sciencedirect.com/science...42727X99000077
http://www.iket.fzk.de/cube/lib/file...0f60e4ecfe.pdf
But they don't seem completely happy. Also, if you set up Ra sufficiently high of course you're gonna get the phenomenon. But are you getting it right?
Old   June 23, 2013, 06:17
Yash Ganatra
Thank you for your reply. Previously i thought that one could get these cells only till a critical number of 1708.
It depends on a lot of factors you are right
Old   June 23, 2013, 06:28
kris pani
Thank you all for the replies. It's not easy to capture, that's true!
benard cells, natural convection
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
