help with boundary profile in pressure inlet
Old   June 18, 2013, 13:28
quiqui is on a distinguished road
Originally Posted by Far View Post
Using density based solver (uniform inlet pressure, averaged from pressure profile data) and solver is running without problems.
Few points :
1. Mesh is not good enough
2. Place outlet further downstream.
3. Check boundary conditions
Which means you did not import the profile as the total pressure @ pressure inlet, you use a specific number? right?
I used to run the case @ 70 psi, it run well, but once I imported the profile, it gave AMG divergence error.
quiqui is offline   Reply With Quote
Old   June 18, 2013, 13:55
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Ok. I got solution for your specific problem.
Choose direction specification method as "direction vector" instead of normal to boundary. now compute from inlet, everything will be fine...
Far is offline   Reply With Quote
Radiation interface hinca CFX 15 January 26, 2014 18:11
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Pressure Inlet Boundary Condition Prasad FLUENT 6 April 9, 2013 22:32
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 23:46
