Journal Batch-mode Solution Animation
Old   June 17, 2013, 10:25
Default Journal Batch-mode Solution Animation
Frederik
RoterFuchs is on a distinguished road
I'm using Fluent 14.5 and want to start it in the batch-mode. It's about an transient job where I don't want to save cas and dat every time step because of the size, instead I want Fluent to save pictures of specific views (and there different vectors or contours). Therefor I used in the online mode "Calculations Activities" --> "Solution Animations", defined my perspectives and everything worked.
For batch mode I wanted to do the same, found out which commands are to use in the TUI:
file/read-case "MyFilename.cas"
file/read-data "MyFilename.dat"
/display/views/restore-view view1
/display/vector/velocity/velocity-magnitude 0 0.2 0.0025 1
/solve/animate/define/define-monitor,1 yes yes 1 vector
ppm,
/display/views/restore-view view2
/display/vector/velocity/velocity-magnitude 0 2 0.005 1
ppm,
solve/set/time-step 2.77e-04
solve/dual-time-iterate 360 50
file/write-data "MyFilename_%t.dat"
exit
yes
view1 and view2 are saved in the data (or case) file. Everything works in the online mode of Fluent via the TUI. But when I start the journal via excutive command it interrups after the line (display/vector/velocity/velocity-magnitude 0 0.2 0.0025 1) and before the text "invalid command [view1]" appears after that line (/display/views/restore-view view1)
Could someone please help me?
thanks a lot for reading
RoterFuchs is offline   Reply With Quote
Old   February 13, 2014, 12:54
Luiz Eduardo
DudaAPD is on a distinguished road
I am also trying to do something similar. Did you manage to solve your problem?
Thx
DudaAPD is offline   Reply With Quote
Old   June 18, 2014, 18:40
obylong is on a distinguished road
Hey, can anyone kindly help out here urgently? I am trying to run a transient simulation in batch mode but I keep having an error message:
Error: No graphics functions are available.
Error Object: ()
My TUI commands is:
; Read case and data files
file read-case-data Rc_transient.cas
solve/set/time-step 2.0e-4
solve/dual-time-iterate 100 20
file write-data transient1.dat
Exit
obylong is offline   Reply With Quote
Old   June 18, 2014, 21:50
Luiz Eduardo
Error Object: ()
My TUI commands is:
Exit
I didnīt understand exactly what you want to do. Is this your journal file? Runnig in a cluster? How are you executing the command for fluent (e.g. fluent 2ddp -g .....). Where does the error appear and when exactly...
I am no expert, but in order to try to help, please give more details...
For now I think (not sure) you should correct the following:
file/read-case-data Rc_transient.cas
file/write-data transient1.dat
And try to do read case and read data separetly if you haven't tried that.
Kind Regards,
DudaAPD
Old   June 18, 2014, 22:09
Kind Regards,
DudaAPD
Hi (thanks for reaching out)
Yes those are the commands in my journal file (valiantsim.jou) running in a cluster. The commands are executed with fluent 3d -g -ssh -pdefault -t${cpus} -i valiantsim.jou
Also the errors appear just seconds after the simulation begins to run and appears just after it reads the the solve/dual-time-iterate command and just about to start running. see below;
Updating solution at time levels N and N-1.
done.
iter continuity x-velocity y-velocity z-velocity kl kt omega delta_time time
Error Object: ()
time/iter
Old   June 20, 2014, 14:48
Luiz Eduardo
I may be wrong, but I don't think it is a problem with your journal file... Probably with your case set up.
Old   March 27, 2019, 12:30
Lukas Fischer
lukasf is on a distinguished road
You have to adjust your fluent command:
fluent 3d -g -ssh -pdefault -t${cpus} -i valiantsim.jou -driver null
does the job.
see this thread:
Save images using Fluent in batch processing mode
lukasf is offline   Reply With Quote
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 13:11
cfdpost in batch mode taichijulie CFX 1 October 25, 2010 16:29
making animation in batch mode in linux rocklove FLUENT 0 July 10, 2010 03:17
Batch Mode (Urgent Help) Mahesh FLUENT 1 June 15, 2007 20:39
help needed about phase change Yanhu Guo Main CFD Forum 4 January 24, 2001 00:16
