Solid particles in a flow
Old   June 15, 2013, 17:56
Default Solid particles in a flow
asier is on a distinguished road
I'm trying to simulate individually defined solid particles (as shows the attached figure) in a fluid of the same or almost the same density.
I have set the VOF multiphase model and define the particles as fluid with very very high viscosity and the fluid is a Newtonian fluid. Both materials have same density.
The problem is when I run the simulation particles are united into a unique volume. I don't want to happen this, in other words particles must not mix together.
I try it to do it as solid material but the interface between the faces is defined as wall and the particles don't move with the fluid.
If anyone can help me, I would be very grateful.
If you have any other idea or way to do the same or something similar it will be welcome.
asier is offline   Reply With Quote
multiphase, multiphase unsteady, particle tracking
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 22:33
Modeling solid particles within fluid flow steelydan ANSYS 1 July 22, 2011 04:01
solid particles sacha CFX 5 November 10, 2003 13:29
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
