3D Fan:Calculation of induced flow rate by fan rotation at free delivery
Old   June 11, 2013, 07:29
Default 3D Fan:Calculation of induced flow rate by fan rotation at free delivery
Catthan is on a distinguished road
Hi guys,
I would like to ask if there is any way to model this (or if there's smth wrong in my thinking)
I have a 3D model of the periodic (1/6th) section of a fan + ducting and would like to get the the flow rate caused by the fan rotation at free delivery (0 pressure rise and max. flow rate from the performance curve).
So far I have reproduced the fan performance curve by varying the flow rates at the inlet and getting the corresponding pressure rise.
Now I am trying to set 0 pressure rise across and get the flow rate as a result of the fan rotation only.
I tried pressure inlet and outlet at 0 gauge pressure and got 0 flow rate
The reason I want to do this simulation is so I can see the effect of different fan designs on the flow rate at fixed RPM later on.
I should be able to figure this out by theory I guess but I'm not there yet.
Thanks for the help in advance.
Thanos
Catthan is offline   Reply With Quote
Old   September 13, 2013, 03:42
nash is on a distinguished road
i have a question , what are the boundaries of inlet and outlet to be used when i want to vary the rpm and want to get the flowrate so that i can have the perfomance curve (Speed rpm and flow rate)??
__________________________________________________ __________________________________________________ __________________________________________________ _________________________
btw. for the fixed rpm, i use totalpressure for both inlet and outlet. I set the p0 at outlet to the value that i want while keep the p0 as 0 at the inlet.
Basically you can plot the performance curve (flowrate and static pressure) easily without need to do extra calculation.
nash is offline   Reply With Quote
Old   September 13, 2013, 06:30
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by Catthan View Post
Hi guys,
Thanos
Do you want to use the zero gauge pressure (0+101325 = 101325 pa absolute pressure) at inlet and outlet?
But I am not convinced with the idea of having zero pressure rise and still have some + mass flow rate.
Far is offline   Reply With Quote
Old   November 6, 2013, 06:19
Abdul Afoo Parkar
A_Prakash is on a distinguished road
Very quickly:
If my fan runs at fixed rpm, is it sufficient to give it a Domian Interface conservative massflow rate BC? Which would be preferred: Interface massflow rate or pressure change?
A_Prakash is offline   Reply With Quote
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
Mass Flow Rate Error jallison FLUENT 1 May 16, 2011 17:22
Mass Flow Rate student87 CFX 4 January 2, 2010 05:45
Target mass flow rate Saturn FLUENT 0 December 10, 2004 05:18
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
