helical coil heat exchanger
Old   June 8, 2013, 06:31
Default helical coil heat exchanger
Sarthak Nigam
sarsam.9296 is on a distinguished road
I am working on a helical coil heat exchanger ( Tube side : Helical coil and Shell: cylindrical)
For solving the temperature profile in Fluent, which model should I use:
Case -1: Both shell side and tube side flow is laminar. But as we know, secondary flow develop in helical coil due to centrifugal force. Because of these secondary flow should I use k-epsilon model or laminar model.
Case-2: Shell side flow is turbulent and tube side is laminar. Which model should I use, K-epsilon or laminar.
Case-3: Is there any way I can define different models for different flow patterns on tube side and shell side.
please reply
sarsam.9296 is offline   Reply With Quote
Old   June 9, 2013, 07:17
ghost82's Avatar
Rick
ghost82 will become famous soon enough
please reply
Hi, I would go for laminar as a first try (both, shell and tube, case 1); you can then switch on k-epsilon for the tube side (RNG could be a good choice) and compare results.
Or you can use a transitional turbulent model, but take care to y+ values.
Case2: turbulent in shell and laminar in tube; same comment as above for the tube zone.
It is possible to simulate one zone with laminar model and one zone with a turbulent one.
Make 2 zones (shell and coil) in pre-processor, then in fluent, choose a turbulent model, but in cell zones, for the laminar zone, check the laminar box.
Daniele
ghost82 is offline   Reply With Quote
Old   January 13, 2016, 07:00
Default helical heat exchanger
supriya mishra
supriyamishra39 is on a distinguished road
can u plzz tell me how to draw the helical shape tube in ansys dm..
plzzz reply..
supriyamishra39 is offline   Reply With Quote
Old   January 14, 2016, 04:02
fresty is on a distinguished road
Though you would find many tutorials for this and procedure might not differ from other 3D CAD softwares; however, generally you could draw a desired 3D (sketch) helix profile (originating from global origin) and a circle (or any planar shape that you would like) on either of the ends with it's centre at the termination of the 3D helix line.. sweep the circle while selecting the helix line as the path..
fresty is offline   Reply With Quote
[ANSYS Meshing] meshing for dual cell heat exchanger sandeep sethi ANSYS Meshing & Geometry 0 December 29, 2012 11:19
[GAMBIT] double pipe heat exchanger with helical fin around inner tube mozafarie ANSYS Meshing & Geometry 5 November 7, 2012 06:02
design of helical coil heat exchanger turbofx35 ANSYS 0 May 5, 2012 02:37
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 03:21
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
