June 3, 2013, 10:46 |
defining boundary
FHydro
Rep Power: 13 |
Hello.
I have a question. suppose, for 3D model, i have a rectangular inlet with dimensions of 8*5. I am defining the boundary like velocity inlet or pressure inlet for this inlet. Now, i want the flow enter to model just from part of this rectangular boundary like the dimensions of 8*3. Is this possible in fluent? If yes, how can i define it? Is the defining of that from Patch in fluent? I read fluent user guide but i didn't understand what the patch is? I am simulating a 3D model in fluent but i have very problems. thanks |
June 4, 2013, 04:56 |
Maxime Perelli
Rep Power: 41 |
As far as I know, Patching is for setting up some cells, but not all cells. (typically initial guess for multiphase).
From what you explained, you will modify the geometry of a boundary. Maybe you would be quicker, if you go back to your mesher...
In memory of my friend Hervé: CFD engineer & freerider |
June 4, 2013, 15:51 |
#3 | |
FHydro
Rep Power: 13 |
i want create the geometry in gambi just once then i define difference velocities and depths for inlet boundary in fluent. |
June 4, 2013, 15:55 |
Rep Power: 17 |
If you want your fluid to enter from only a region of the face, then define that region as the inlet and the rest of the face as a wall.
If you want a gradient of velocity across your inlet, you will have to write a profile and define that to your inlet. A patch is used only for volume initialising Regards Luke |
June 4, 2013, 16:55 |
#5 | |
FHydro
Rep Power: 13 |
yes i want fluid to enter from only a region of the face, but i can't define the rest of the face as a wall. please see attached image |
June 4, 2013, 18:01 |
Rep Power: 17 |
The red face has to have a separate name, different from the rest of the face.
I'm not sure if you can split the face in Fluent Regards Luke |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 06:57 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 06:58 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
problem on defining a nonuniform iac boundary condition | pfhan | FLUENT | 1 | July 16, 2011 12:32 |
Boundary conditions? | Tom | Main CFD Forum | 0 | November 5, 2002 02:54 |
