temperature contour - heat exchanger
Old   June 3, 2013, 06:25
Question temperature contour - heat exchanger
Lagunesvary
chinna is on a distinguished road
Hai, im simulating transient heat exchanger inside storage tank by Fluent 14.0. when i record solution activity, the temperature contour somehow not as i expected. im not sure how to solve it.
as the time runs, the heat should spread around the storage tank right but in my case, it`s only spread around the tube. thats how the temperature contour shows.
the hot flow inside the tube - 373k (flow rate 1kg/s)
tank water - 300k
i coupled the interfaces of both domain.
could it be initialization problem..?? please help me...
chinna is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Heat Exchanger Model sak2129 FLUENT 3 September 26, 2017 02:29
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
2D heat exchanger problem Kwiaci FLUENT 0 June 7, 2012 08:12
Pressure drop in a heat exchanger Diana FLUENT 5 December 13, 2007 10:33
