April 28, 2013, 15:48 |
T channel in single rotating reference frame
afluent
Rep Power: 13 |
Hello
i want to simulate a T channel in single rotating reference frame. i studied user guide and tutorial . according to them i should choose 2D option in solver ( Define-Solver-2D) not axisymmetric or axisymmetric swirl . but when i just choose 2D after that in defining boundary condition for fluid when i choose moving reference frame, it doesn't ask for rotational speed? i would be grateful if anyone could help me. |
May 2, 2013, 14:10 |
Thomas D. Economon
Rep Power: 14 |
Hi afluent,
Could you please describe your case/mesh in a little more detail? Perhaps you could share a picture of your geometry? Thanks, Tom |
May 14, 2013, 03:11 |
afluent
Rep Power: 13 |
Hi Tom
Thank you for your reply and excuse me for delay in responding i attach the figure of my geometry. there is one inlet at left and 2 outlet in right side and bottom. my problem is according to user guide this geometry is just 2D ( not axisymmetric or axisymmetric swirl like tutorial guide example) and when i choose 2D in solver , after that, in defining boundary condition when i choose moving reference frame for fluid it doesn't ask me the rotation speed! thus the answer is not true! i attach mesh file too if it was allowed. Thanks a lot. Best Regards |
May 21, 2013, 04:21 |
Thomas D. Economon
Rep Power: 14 |
Hi afluent,
I am unfamiliar with the test case that you are attempting to solve. Can you please share the link or documentation for this problem so that I can better understand the problem? Thanks! Tom |
May 22, 2013, 04:29 |
afluent
Rep Power: 13 |
Hi Tom
thanks for your reply this problem is not in any site that i can link to. consider a disc which is rotating at a constant velocity. there is a channel like the image attached to previous post on the disc which contain fluid. so for modeling this fluid on disc, we should model the channel in single rotating frame. according to the user guide of fluent my problem is not axisymmetric and its just 2d. in tutorial guide in solver panel , it choose axisymmetric swirl appropriate to their problem. I proceed just like the tutorial but just in solver panel i choose 2D instead of axisymmetric swirl . after that in boundary condition for fluid when i choose moving reference frame (like tutorial) it does not ask me the rotation speed! and my deviation from tutorial was just 2D instead of axisymmetric swirl! what should i do?where is my problem? thank you so much and accept my apology for this long text. |
May 23, 2013, 04:18 |
Thomas D. Economon
Rep Power: 14 |
Thanks for the explanation, but I am still a little confused... Are you attempting to solve this problem using SU2 or Fluent?
May 23, 2013, 04:30 |
afluent
Rep Power: 13 |
Hi
i want to model it in fluent. Thanks |
Rotating Reference Frame Pressure Gradient | clac | FLUENT | 0 | August 22, 2012 19:20 |
Different solutions for Rotating Reference Frame | fafou09 | FLUENT | 1 | July 24, 2012 11:06 |
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile | val46 | OpenFOAM Installation | 4 | August 27, 2010 04:43 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 07:14 |
Windows Installation BugsComments on Petrbs patch | brooksmoses | OpenFOAM Installation | 48 | April 16, 2006 01:20 |
