Problem in using system coupling in ANSYS 14.5
Old   May 23, 2013, 00:14
Question Problem in using system coupling in ANSYS 14.5
yehanyu
yhy20081016 is on a distinguished road
I am using the "System Coupling" module in ANSYS Workbench 14.5 for fluid-structure interaction simulation. I encountered problems when I try to set initial conditions for the fluid region.
I want to use a steady-state-flow result as initial conditions for the unsteady simulation. Therefore, before I start the unsteady simulation, I execute the [File]|[Interpolate...] command in FLUENT to import a previously obtained result.
However, the system coupling solver seems to totally ignore this imported result, and, instead of using this imported result as initial conditions, it use the initial values in [Solve]|[Initialization...] page to initialize the flow field at the beginning of the unsteady simulation.
I am looking forward to a solution to resolve this issue.
yhy20081016 is offline   Reply With Quote
Old   April 16, 2016, 08:39
Unhappy i have also the same problem
mohammad
mmkkeshavarzi is on a distinguished road
can you give me instruction if you solved that problem plz
it is really annoying
mmkkeshavarzi is offline   Reply With Quote
ansys, fluent, initial condition, system coupling
Problem in coupling CFX and Ansys for fluid-thermal sim. Jordi CFX 21 March 1, 2017 06:03
Restarting batch job of system coupling in ANSYS14 bbhv ANSYS 0 June 25, 2012 09:30
Problem of Ansys for machanical a element or a group of elements lovelyeverything ANSYS 0 April 18, 2012 23:54
System Coupling in ANSYS 14 bbhv FLUENT 2 March 12, 2012 19:48
ANSYS 13 problem zona ANSYS 0 December 16, 2010 07:48
