Help: Create offset surface from existing surface??!!
Old   May 22, 2013, 06:37
Default Help: Create offset surface from existing surface??!!
Tobias
tobiley is on a distinguished road
Dear All,
I have a surface in Fluent and would like to create a new one for post processing, which has just an offset to the old one. Is there a similar way to do it like in a CAD programm (grab the old one and then define an offset)?
The thing is that it is for expample a concial surface which I cant create with iso-surfaces via the mesh values (x,y,z, angular,...)
Thanks a lot for your help!
Regards, Tobias
tobiley is offline   Reply With Quote
Old   May 22, 2013, 07:36
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Surface -> Transform
then traslate or use offset according to the needs
sbaffini is offline   Reply With Quote
Old   May 22, 2013, 08:34
Tobias
Thank very much!!!
That works! The only question I have, when I use Iso-Distance, which gives me an offset to my surface, I'll get the offset to both sides. Is it possible to get it only to one side?
Regards, Tobias
WARNING:''cannot create surface from sliding interface zone'' bahar FLUENT 12 March 22, 2013 16:03
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
Create a virtual Surface into a domain in CFX PRE chuck209 Main CFD Forum 0 August 13, 2012 13:10
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 14:43
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
