Rep Power: 16 ![]() |
I am modeling coal combustion with non-premixed combustion and dpm. I am checking fluxes after the calculation. Mass flow balances out and shows the correct flows including the coal particles. however, when I check the heat transfer it shows less heat input from the dpm. Coal flow is 400,000 lb/h (mass flow is correct) and Coal HHV is 10,000 btu/lb (this value entered in coal calculator) so I should have 4,000mmbtu/hr heat input from dpm. Instead it shows me only 1,000mmbtu/hr from dpm. FYI I am providing more than enough air to complete the combustion. Any ideas? Thank you in advance. |
Coal combustion injection properties | semo | FLUENT | 12 | May 16, 2017 19:40 |
Problem on EDC model for coal combustion | lei | FLUENT | 4 | September 3, 2015 09:39 |
Coal combustion and ash reaction kinetics | sega | Fluent UDF and Scheme Programming | 0 | January 21, 2010 08:05 |
moisture in coal combustion | Sheng | FLUENT | 3 | June 15, 2003 19:43 |
Coal combustion with Fluent 4.5 or 5.0! | Sriram Popuri | Main CFD Forum | 2 | July 24, 1999 11:34 |
