create overlapping geometry
Old   May 15, 2013, 05:44
Question create overlapping geometry
Lagunesvary
chinna is on a distinguished road
Hai,Im simulating shell and tube heat exchanger with ansys fluent 14.0. i wanted to use heat exchanger option under model but it says the zones are not overlapping. can anyone please help me with this. how to create overlapping zone between hot and cold fluid? please help me, the submission date is this friday. pleassseeee...thank you
chinna is offline   Reply With Quote
Old   May 16, 2013, 04:15
Lagunesvary
Dear All,
I would appreciate if anyone could help me.
Thank you.
Old   May 16, 2013, 10:57
venki
venkateshaero is on a distinguished road
Check the help file of fluent its there
venkateshaero is offline   Reply With Quote
Old   May 16, 2013, 12:10
Lagunesvary
ya..i have go through it..it says..
If the mesh file does not already contain overlapping heat exchanger cores for primary and auxiliary fluids, then you must create a duplicate of the zone that represents the core using the following text command:
mesh → modify-zones → copy-move-cell-zone
and when i try it at fluent...
modify-zones/: Enter the modify zones menu.
?: Enable help mode. Type "q" to return to command mode
invalid command [copy-move-cell-zone]
/mesh> 3
invalid command [3]
3 is the ID of the zone
i dont know how should i respond it... i keep on trying..but my command being invalid...
how should i respond back??
Old   May 16, 2013, 13:56
venki
/mesh/modify-zones> slit-face-zone
Face zone id/name [] wall-4
Old   May 16, 2013, 14:01
venki
https://www.google.co.in/url?sa=t&rc...YfT5JDkWUPdtsQ
Old   May 17, 2013, 17:04
Lagunesvary
thank you..but due to time limitation..i just drop on using heat exchanger model. i used interface couple method.. it was succeed... but im not sure what i did is correct...
coupled solver
time step time-5s
number of time step-28
the length of the shell is 70cm & velocity 0.5cm/s
the length of tube-580cm - velocity 5cm/s
i just did small calculation as the fluid in shell need atleast 140s to out of it & the fluid in tube needed 116s to out...thats how i come up with the time step time and the no. of it... 5s*28=140s...
is it correct...??
overlapping
create turbine geometry with gambit badlaine ANSYS Meshing & Geometry 2 March 27, 2012 00:54
what after create my geometry happy CFX 6 November 26, 2010 04:22
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Create 2d geometry file with pro*am? raymond Siemens 1 December 13, 2001 11:31
Virtual/Real geometry. Jack Keays FLUENT 9 June 16, 2000 00:39
