command TUI / Scheme for stop and continue calculate
Old   May 13, 2013, 06:48
Default command TUI / Scheme for stop and continue calculate
rayolau
rayolau is on a distinguished road
Hi all,
I'm looking for how do, with a command TUI / Scheme, that continue the calculate after first iteration stop, inside first time step.
for example, for a time step size of 1 second with 3 iterations/time step, I need this:
First time step:
1º iter --> stop, continue -->2º iter: stop, continue --> 3º iter: stop, continue -->
Second time step:
n time step...
In resume, I need two commands: one for stop and one for continue. For that will executed at the end of each iteration, In the menu "Solve / monitor / Commands / Command" is possible to set text and Scheme commands and these will then at each iteration.
I read Scheme Programing in FLUENT 5 & 6*, but I don't find that I need. http://www.polo.ufsc.br/~tiagom/docu...programing.pdf
Any ideas?
Thanks in advance!
rayolau is offline   Reply With Quote
Old   May 13, 2013, 11:20
blackmask will become famous soon enough
Try the combination of iterate and update-physical-time, i.e.,
/sol/iter N1
/sol/iter N2
/sol/iter N3
/sol/up-phy-ti
But I am not sure whether it works or not.
blackmask is offline   Reply With Quote
commands, continue, iteration, stop, tui
2D CFD code using SIMPLE algorithm bfan Main CFD Forum 3 June 22, 2002 23:01
EULER-Forward-Method freak Main CFD Forum 4 June 12, 2001 10:19
