viscous heating and constant wall temperature |
May 1, 2013, 11:41 |
Tajul
Rep Power: 17 |
Hi
I am simulating microflow. My simulation is 2D with inlet temp. 350K and two walls with 300k. The inlet and outlet pressure condition. I want to keep constant wall temperature. I added viscous heating term. I get the result which seems wrong. The simalation should give negative heat flux, but it gives positive heat flux. Also Tm (Mean temperature) should greater than wall temperature. But Tm is less than Tw ( wall temp). Can anybody explain why? Thanks in advance. Abir tajul000@yahoo.com |
May 4, 2013, 09:25 |
Sa.Baraty
Rep Power: 13 |
dear abir
you must adjust refrance value in fluent. such as inlet area, length and etc thanks |
May 5, 2013, 11:13 |
Tajul
Rep Power: 17 |
Dear sara22
Thanks for your reply. I did as you said but could not succeeded. I sent you the cas and dat files. If possible please help me. Have a nice time. Abir tajul000@yahoo.com |
May 5, 2013, 11:25 |
Tajul
Rep Power: 17 |
Dear sara22
Thanks for your reply. I did as you said but could not succeeded. I want to send you the cas and dat files so your email address is needed. If possible please help me. Have a nice time. Abir tajul000@yahoo.com |
May 5, 2013, 16:02 |
Sa.Baraty
Rep Power: 13 |
May 17, 2013, 13:17 |
Tajul
Rep Power: 17 |
Hey
Where are you |
Free stream temperature in tube wall | saharesobh | FLUENT | 2 | November 19, 2012 08:32 |
Free stream temperature | saharesobh | FLUENT | 1 | October 11, 2012 21:52 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 18:12 |
temperature of the last grid of the wall at the exit is decreased | dsanthosh2 | FLUENT | 0 | June 7, 2012 04:42 |
Impact temperature on an aircraft | Santos-Dumont | FLUENT | 2 | August 18, 2011 13:01 |
