Wind Turbine (VAWT) - Negative Moment in Fluent
Like Tree8Likes
Old   April 30, 2013, 09:04
Default Wind Turbine (VAWT) - Negative Moment in Fluent
dalecooper
dalecooper is on a distinguished road
Hello!
I am doing some research about Vertical Axis Wind Turbine (VAWT) for my master thesis. I have been doing some simulations with Fluent with a 4 bladed turbine. The radius of the turbine is 3 meters.
The main target is to obtain a profile of the Coefficient of Perfomance (Cp) versus the Tip Speed Ratio (TSR). In Fluent I'm using a sliding mesh technique with 1 interface to separate the rotating zone from the stationary zone.
The problem I found is that whatever value of TSR I choose I never get a positive moment coefficient. I have tried to refine the mesh and reduce the time step but that didn't solve the problem.
Any idea or solution would be well received. Thanks in advance!
Ansys2015 and haiderr like this.
dalecooper is offline   Reply With Quote
Old   April 30, 2013, 09:58
blackmask will become famous soon enough
You should do the steady simulation with SRF/MRF first. This way you need not warry about the time step size and yet the converged result can be used as a starting point for unsteady sliding-mesh based simulation. If this is a realy turbine, you could ask the designer about the optimal TSR. Do you happen to rotate in the wrong direction?
blackmask is offline   Reply With Quote
Old   April 30, 2013, 11:19
dalecooper
Hello blackmask.
I have already used this approach of beginning with a steady simulation with an angular velocity equal to 0 rad/s as my thesis director suggested to me. After that and when the results have converged I move to transient simulation using a constant inlet velocity of 10 m/s and changing the value of the rotational speed in order to simulate different values of the TSR.
I'm using 'Transition SST (4 eqn)' with the default options as a viscous model and I'm not sure if that could be the problem. I have also tried with different solution methods but apart from the covergence velocity no significant changes were detected in Cm.
Old   April 30, 2013, 11:32
No. You should start your simulation with 10m/s inlet velocity and an appropriate rotational speed using the MRF (moving reference frame) technique. You should check the fluent user's guide if you are not familiar with MRF. The default parameters of specifying b.c. for TR-SST could results in an unresonable high turbulent viscosity at the inlet but I do not think it is the reason that you get negtive torque.
Old   May 4, 2013, 02:57
Reza
CFD_LES is on a distinguished road
Hello dalecooper
I work on a 4-Bladed VAWT with semi-circle blade. I obtain ((Negative)) moment for this VAWT.
You obtained negative moment too. Did you understand the reason?
Could you solve your problem?
Also I have to say, My problem is steady.
Thanks so much
CFD_LES is offline   Reply With Quote
Old   July 8, 2013, 07:58
dalecooper
Originally Posted by CFD_LES View Post
Hello dalecooper
Thanks so much
Hello CFD_LES,
Finally I was able to solve my problem of negative Cm values in my simulations. All I did was to restart again with the geometry and meshing. So I think there was some problem with the interfaces between the stationary and rotating domains, but I'm not sure if that was the reason. All I can tell you is that after that I began to obtain positive Cm values.
Nowadays I'm doing some simulations in order to obtain the coefficient of performance of the turbine as a function of the tip speed ratio (TSR). The results look pretty good except, for a unique point (TSR=1.5) where the Cm has an abnormal value. I was expecting to obtain an increasing Cm value up to a certain point where the turbine is most efficient, and after that the Cm should begin to decrease.
I have tried with different inlet velocities, but the behavior is exactly the same, and also the critical point is located at TSR=1.5
Best regards
israa and haiderr like this.
Old   October 8, 2013, 04:53
Michael Bausas
mikebausas is on a distinguished road
hello dale cooper,
I am working with a 2d model VAWT which i simulated using fluent. And now, I generated some results of Cm from the iterations. My question is, what would be my next step in order for me to conclude that the results are acceptable or accurate for the specific turbine I am testing? Where shall I compare my results with? And how did you compute for the other parameters, such as Cp, Torqu, etc? Does Fluent also gives these data? Thanks
Regards,
Mike
mikebausas is offline   Reply With Quote
Old   October 8, 2013, 06:06
dalecooper
Originally Posted by mikebausas View Post
hello dale cooper,
Regards,
Mike
Hello mikebausas,
In turbines, one of the most important graphic to obtain is the one that compares the Cp vs TSR (Tip Speed Ratio). From Fluent you can obtain directly the Cm (Coefficient of Moment). Once you get the Cm you must average the values obtained through a number of periods assuring that you have reached a steady solution and use the following equation to obtain the coefficient of performance (Cp):
Cp=Cm*TSR
What I have been doing is simulate for different values of TSR. To do that you have to change the value of the rotational velocity of the sliding mesh zone in which you locate the airfoils for every TSR value.
Regards.
didane likes this.
Old   April 3, 2014, 05:42
Ali
mct90 is on a distinguished road
Originally Posted by dalecooper View Post
Hello mikebausas,
Cp=Cm*TSR
Regards.
Hi Dalecooper. i am also studying similar project.
I want to know, to obtain a CP-TSR graph like the image, does the cm decrease at a value of rotational velocity(w).
For ex; w=1,tsr=1 cm=0.12 ---w=2,tsr=2 cm=0.20---- w=3 trsr=3 cm=0.18 ---.
mct90 is offline   Reply With Quote
Old   April 6, 2014, 23:56
behzad shahizare
shahizare is on a distinguished road
Send a message via Skype™ to shahizare
Attachment 29809
Hi Dalecooper
kindly please help me . i simulate vawt in fluent in 2d and 3d model . i have problem with a reference numbers in fluent , what do you think how much i should put for area and length . and after getting results (cm) how can i convert it to Cp?
shahizare is offline   Reply With Quote
Old   May 5, 2014, 15:03
shafqat
shafqat is on a distinguished road
hi i just want to know why my Cm keeps on increasing at high tsr..i mean it has to decrease after optimal tsr
shafqat is offline   Reply With Quote
Old   May 14, 2014, 07:32
Ali
Originally Posted by shahizare View Post
Hi Dalecooper
I am working 2d vawt. In reference values i took length=R (rotor radius) and Area= 2*R*h .(h=1 because of 2D). references are below;
http://www.iaa.ncku.edu.tw/~aeromems...%20control.pdf (page 341 )
Impacts of solidity and hybrid system in small wind turbines
performance M.H. Mohamed (page 497)
Old   May 15, 2014, 03:46
behzad shahizare
abi nasilsin
this is link of my work https://www.dropbox.com/sh/c2hl306cm...Tm6mI8i8xX2T8a
actually in what reason i dont know why i can not get good validation with my reference . is it possible for you to check my case file?
tasakor lar
Old   May 30, 2014, 01:05
Aalisha
aalisha is on a distinguished road
Hello CFD Mates!!
I am a Masters student working on a vertical axis marine current turbine. I am using Fluent for the required simulations. To calculate the Cp, I have monitored the value of Cm, Cl and Cd.
However, the value obtained for Cm is very high ( 85, 70 etc). If anyone can guide me what is the reason for this. It will be a great help. Thanks.
aalisha is offline   Reply With Quote
Old   August 7, 2014, 11:19
amin veysi
amin_veysi is on a distinguished road
Originally Posted by aalisha View Post
Hello CFD Mates!!
hi aalisha change the reference value,
reference value panel, change the velocity, area and length
amin_veysi is offline   Reply With Quote
Old   August 11, 2014, 23:56
Aalisha
Hey Amin,
Thanks for your kind reply. I tried it and its working now.
Old   January 20, 2015, 22:30
WenBin.JU
JUDASHU is on a distinguished road
hi
I am doing a 2D VAWT CFD simulation with Fluent, and I have my reference valus as you suggested, I still wonder what the "compute from" and "reference area" should be, and I have got a CM curve in my attachment, it seems fluctuates drastic, so is this a normal case or did I have something wrong in my case?
Ansys2015 likes this.
JUDASHU is offline   Reply With Quote
Old   March 10, 2016, 18:14
Qusyairi Amiruddin
urbanzakapa is on a distinguished road
Hello CFD_LES,
Best regards
I really need your help, when I did mine, VAWT 3blade, all I got for Cm are very small values, all of them, for example, 0.02, so then my Cp would be small too, because Cp=Cm*TSR, so I am now start to wonder whether I have done it wrong since the first step,
Can I get your help over these problem, please, thanks.
Here is my email: qusyairi315@yahoo.com
urbanzakapa is offline   Reply With Quote
Old   March 11, 2016, 02:49
Raj
rgunjegaonkar@gmail.com is on a distinguished road
hii aalisha,
would like to conform reference values
Velocity- Velocity of wind
Area-Area of inlet side
Length-Flow length
thank you.
rgunjegaonkar@gmail.com is offline   Reply With Quote
Old   March 11, 2016, 03:06
Raj
hello sir,
i m simulating helical vertical axis wind turbine....confused little bit...while using MRF Model only fluid domain should be rotated or Fluid Domain+wall Blade.
Thank you in advance.
waiting for reply.
Wind Turbine on FLUENT federvo.mala ANSYS 21 July 3, 2013 03:05
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Moving reference frame in wind turbine kongl1986 FLUENT 0 March 30, 2013 11:50
2D Simulation of Savonius Wind Turbine ravindersingh FLUENT 4 December 9, 2011 14:00
Boundary Condition for ducted wind turbine using FLUENT Styward FLOW-3D 2 October 30, 2009 01:53
