Wind Turbine (VAWT) - Negative Moment in Fluent
Like Tree8Likes
Old   June 16, 2016, 09:10
Luke
aerospace84 is on a distinguished road
fluid domain around blades and blades should be rotating!
aerospace84 is offline   Reply With Quote
Old   October 25, 2016, 00:00
djamal
didane is on a distinguished road
Originally Posted by urbanzakapa View Post
I really need your help, when I did mine, VAWT 3blade, all I got for Cm are very small values, all of them, for example, 0.02, so then my Cp would be small too, because Cp=Cm*TSR, so I am now start to wonder whether I have done it wrong since the first step,
Can I get your help over these problem, please, thanks.
Here is my email: qusyairi315@yahoo.com
Dear Qusyairi Amiruddin, Have u solved your problem? i'm encountering similar problem too..Thanks in advance
Kind regards
didane is offline   Reply With Quote
Old   January 29, 2017, 02:41
LordF
FaSe is on a distinguished road
Originally Posted by dalecooper View Post
Hello CFD_LES,
Finally I was able to solve my problem of negative Cm values in my simulations. All I did was to restart again with the geometry and meshing. So I think there was some problem with the interfaces between the stationary and rotating domains, but I'm not sure if that was the reason. All I can tell you is that after that I began to obtain positive Cm values.
Nowadays I'm doing some simulations in order to obtain the coefficient of performance of the turbine as a function of the tip speed ratio (TSR). The results look pretty good except, for a unique point (TSR=1.5) where the Cm has an abnormal value. I was expecting to obtain an increasing Cm value up to a certain point where the turbine is most efficient, and after that the Cm should begin to decrease.
I have tried with different inlet velocities, but the behavior is exactly the same, and also the critical point is located at TSR=1.5
Best regards
Hi all,
I am simulating a 2D VAWT with 2 blades in ANSYS Fluent 16. I am validating my results (Cp vs TSR). at the interval 1.2<TSR<2 , i get good results but in the range TSR<1.2 , i get negative values for Cp (Coefficient of Power) and in the range TSR>2 , Cp values increase by increasing TSR which is not correct because Cp should reach to a maximum value for a specific TSR and after that should decrease.
I am doing my thesis and REALLY NEED YOUR HELP.
FaSe is offline   Reply With Quote
Old   March 10, 2017, 09:45
Mabrouk
Mabrouk is on a distinguished road
hello,
How can i do a good mesh for hydro turbine?
Mabrouk is offline   Reply With Quote
Old   September 12, 2017, 22:06
Default Cm in axis is too small
  #25
rudi purwo
rudipewe is on a distinguished road
Send a message via Skype™ to rudipewe
Dear All,
Would u please help me. I am a newbie in Ansys Fluent. I do the simulation of VAWT with rotation and revolution on the blade. I got the good result on blade Cm, but not on axis (rotor) Cm. Herewith my mesh, and excel result for axis and blades. Thank you very much..
rudipewe is offline   Reply With Quote
Old   December 14, 2018, 10:29
Mehmet
mstrkr is on a distinguished road
Hello everyone
I have problem with my project. I have analyzed hydro turbine in pipe. When I m increasing the TSR value I m getting increasing Cp value contuniously. Even Cp is exceed 1. So there is a problem but I dont know what. Please help me...
mstrkr is offline   Reply With Quote
Old   June 15, 2023, 12:16
CFD
satyamshk2 is on a distinguished road
Area= Diameter of the turbine in 2D
Length= Radius for moments, Depth=1 for 2D
Velocity as a free stream
satyamshk2 is offline   Reply With Quote
Old   December 14, 2023, 06:03
CFD
Area-Diameter of turbine as H is unity
Length= radius of turbine to calculate torque
velocity-inlet freestream
Wind Turbine on FLUENT federvo.mala ANSYS 21 July 3, 2013 03:05
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Moving reference frame in wind turbine kongl1986 FLUENT 0 March 30, 2013 11:50
2D Simulation of Savonius Wind Turbine ravindersingh FLUENT 4 December 9, 2011 14:00
Boundary Condition for ducted wind turbine using FLUENT Styward FLOW-3D 2 October 30, 2009 01:53
