April 22, 2013, 12:12 |
Supersonic free jets from CD nozzle
Naveen S Das
Rep Power: 13 |
Hi Friends !!
I am new to Fluent.. I am trying to simulate a 2D supersonic free jet from a Convergent Divergent nozzle.This is how i set up my problem I am using 2d axisymmetric, steady implicit formulation. Operating pressure=98950Pa. I am expecting oblique shocks at the exit. I went for a Density based solver and realizable K-e Model for turbulence. Nozzle Inlet pressure=465250Pa (Pressure Inlet B.C). The upper part of the nozzle, I went for wall b.c and the right end of the domain is pressure outlet and the bottom part is the axis. My domain is 22D in axial direction and 5D in the radial direction For Left and the upper part of my domain, I had initially gone for pressure inlet B.C with gage pressure=0. But I started to get warnings “temperature limited to 5000K”. I found out that the sharp edge was giving the problem. I refined the mesh close to the sharp edge. But still divergence occurred. Then I got a suggestion from a friend to change the left and upper domain b.c to pressure outlet. With that, I was not having that much a problem with sharp edge. But still my residuals are diverging after initially showing a downward trend. I even started with a courant number of 0.05 and reduced the URFs. I used first order difference schemes. But I cannot get a converged solution.. Is there any problem with the B.C’s or turbulence model? Please help me.. Thanks in advance !! Naveen Last edited by naveensdas; April 22, 2013 at 14:01. |
April 22, 2013, 23:42 |
Naveen S Das
Rep Power: 13 |
Hii Ali
Thanks for replying.. !! i am posting the screen shot of my mesh. will send you the dbs file by mail if you want Last edited by naveensdas; April 23, 2013 at 05:10. |
April 23, 2013, 01:22 |
Chris, Kam
Rep Power: 16 |
did you set the initial pressure as "0"?
or outlet pressure as "0"?? because, what I know is that you can't get exact solution of rarefied gas dynamics with fluent sorry about my weird English, I'm not good at this language :z or you can set the nozzle-inlet condition gradually (set 1 atm for the condition and iterate, set 1.2 atm when the changes of residuals seeme stable, .... set real condition) |
April 23, 2013, 01:27 |
#5 | |
Naveen S Das
Rep Power: 13 |
I have given operating pressure as 98950 Pa (which is the ambient pressure) .. so if i give the gage pressure as 0, then is it a problem? |
April 23, 2013, 01:39 |
Chris, Kam
Rep Power: 16 |
I'm not sure, but.. I heard that 0 pa for operating pressure is good for compressible flow
(I always set like that) |
April 23, 2013, 03:04 |
Naveen S Das
Rep Power: 13 |
April 23, 2013, 03:41 |
Chris, Kam
Rep Power: 16 |
keep the initial condition as ambient will be nice
April 23, 2013, 04:05 |
#9 |
Naveen S Das
Rep Power: 13 |
Hii Chris !!
I have tried to run the simulation with operating pressure=0 and setting initial guess pressure as ambient.. i also went for first order discretization schemes to begin with and a courant number of 0.5.. residuals were decreasing to 5*10^-2.. but then i get the warning "time step reduced in cells" and the number of such cells goes on increasing and with that residuals too started increasing... Last edited by naveensdas; April 23, 2013 at 04:53. |
April 24, 2013, 13:49 |
#10 |
Naveen S Das
Rep Power: 13 |
I would also like to know if my B.Cs are correct..?
April 25, 2013, 02:15 |
#11 |
Chris, Kam
Rep Power: 16 |
I think so,
If you don't mind, could you pass your case file? |
April 25, 2013, 03:38 |
#12 |
Naveen S Das
Rep Power: 13 |
April 25, 2013, 05:49 |
#13 |
Chris, Kam
Rep Power: 16 |
April 25, 2013, 07:00 |
#14 |
Naveen S Das
Rep Power: 13 |
Hii Chris
i have mailed you the case file |
May 2, 2013, 13:07 |
#15 |
Naveen S Das
Rep Power: 13 |
Hii Chris,
Could you identify any mistakes? |
LES supersonic free jet | martyn88 | OpenFOAM | 22 | April 17, 2015 07:00 |
Supersonic turbulent free jet LES | martyn88 | OpenFOAM Running, Solving & CFD | 7 | July 1, 2013 11:51 |
reversed flow in over-expanded supersonic nozzle | imnull | FLUENT | 0 | March 28, 2013 11:48 |
C-D nozzle supersonic jet boundary | Gland | FLUENT | 4 | May 24, 2012 01:25 |
some questions for supersonic channel nozzle | goldenland | FLUENT | 2 | November 4, 2007 22:18 |
