Refrigerant R134a Phase Change
Old   April 22, 2013, 06:14
Default Refrigerant R134a Phase Change
Mahesh
Mahesh Bondhu is on a distinguished road
I am new to Phase change simulation.
Currently i am simulating the evaporation of R134a Refrigerant at constant temperature, I have used the Evaporation and condensation model which is available in Ansys 14.0 . I am not understanding how the model is working. I have few doubts on this model
1. How can we maintain the constant temperature during phase change
2. What is the evaporation frequency i.e 0.1., in Ansys 14. 0 model.
3. How can we define material properties of liquid and vapor
i have defined material properties of liquid and vapor standard state enthalpies in the following manner
liquid 213,58 kj/kg vapor 404.32 kj/kg reference temperature 298.15 K for liquid and vapor.
can any one help me .......how to proceed and how to define material properties.
4. Whether available Evaporation-Condensation model suitable or not, for phase change application in refrigeration
5. What is the backflow volume fraction at outlet.
Please help me
Mahesh Bondhu is offline   Reply With Quote
Old   April 24, 2013, 13:05
Default I Face the same problem but for R410A
khaled yousef
Khaled yousef is on a distinguished road
Khaled yousef is offline   Reply With Quote
Old   April 26, 2013, 07:18
Mahesh
Yousef,
Can you tell how to load the real gas models in Fluent. I have followed the Procedure which was given in Ansys text commands. Its showing invalid commands
>define/user-defined/real-gas-models/nist-real-gas-models
Please help me
Old   May 2, 2013, 02:57
Amit Singh
amit112amit is on a distinguished road
You must be having an older version of Fluent. I have used the command and it works in Ansys 13 which has Fluent 13. I have also tried to use it in Fluent 6.2 and it said "Invalid command".
amit112amit is offline   Reply With Quote
Old   May 4, 2013, 09:13
athonyburk is on a distinguished road
You can find some details about the Evaporation-Condensation Model in the following URL:
https://www.sharcnet.ca/Software/Flu...th/node344.htm
I don't think you need to define standard state enthalpies since you might not expect chemical reactions to occur.
By the way, what multiphase model do you use?
athonyburk is offline   Reply With Quote
evaporation, refrigerant
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 07:37
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 02:49
what approach for direct mixing fluids with heat transfer and phase change? hennas Main CFD Forum 0 June 9, 2009 16:44
Phase change phdsantos FLUENT 0 March 20, 2009 11:19
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 04:59
