Modelling capillary forces using the VOF Model |
April 18, 2013, 04:35 |
Hi everyone,
I am having trouble with the tutorial 'Chapter 20: Using the VOF Model'. In principle my problem is almost identical to the presented one, I want to simulate a drop of water sitting on a plate with various wetting angles. I later want to go to more complex geometries but this is my test-case where I have experimental data for comparison. I am modelling an 2D axysymmetrix domain that is 5x5 mm (that gives a 3D volume of a 10x5mm cylinder) and the drop is initiated as a half sphere with 3mm diameter. I set a wetting angle of 100° and should see how the drop is 'bending inwards' at the interface with time to reach an equilibrium eventually. I am doing everything exactly the same as in the tutorial, up to the step where I have to specify the phase interactions (step 3). there I cannot select 'Surface Tension Force Modelling' and I also notice that the Tab 'Interfacial Area' is missing in my menue. I attached a picture from my Phase Interaction Window. Any Idea what the reason could be? I am using ANSYS 13.0 Thank you very much, Alex |
October 28, 2013, 10:14 |
Rep Power: 13 |
Hey, I did droplet model with surface tension on 2D axisymmetric, send me your doc so that I can look through.
mehmet.yigit.balta@gmail.com http://de.tinypic.com/r/157irua/5 |
Modelling falling solid sphere using interFoam VOF model | eelcovv | OpenFOAM Running, Solving & CFD | 6 | August 7, 2021 21:52 |
can melting model and vof model be used together? | wanghong | FLUENT | 3 | February 26, 2017 23:49 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
modelling solids viscosity in eulerian multiphase model | derkaiser | FLUENT | 1 | December 5, 2011 03:42 |
Modelling flow around a ship's hull using vof | Manoj Kumar | FLUENT | 0 | February 26, 2005 16:22 |
