Radial Turbine Analysis B.C Problem
Old   April 18, 2013, 04:06
Default Radial Turbine Analysis B.C Problem
Yang Ju-Suk
yjs1027 is on a distinguished road
Im now research about radial turbine.
And using Fluent for CFD analysis.
I use MRF model under
Density Base
SST K-w.
and initial condition are below
inlet total pressure : 998430 pa
inlet total temperature : 358K
inlet mass flow rate : 0.402 kg/s
outlet total pressure : 166405 pa
outlet total temperature : 230K
So, i use pressure inlet and pressure outlet as B.C of this model.
Put inlet total pressure and temperature in pressure inlet,
and put outlet total pressure and temperature in pressure outlet.
Furthemore, i put 0 pa in operation pressure.
But in has not conversing.
What is problem of this model?
I have not enough time for submit my paper TT
Please help me.
yjs1027 is offline   Reply With Quote
Axial Flow Turbine Problem Manish FLUENT 1 February 14, 2017 04:46
Radial turbine problem ingmecc FLUENT 3 January 22, 2012 22:26
Turbine: Transient Simulation Problem John C. CFX 7 December 5, 2011 09:31
radial turbine flow analysis ME FLUENT 0 July 2, 2007 10:18
Usage of Star-CD in analysis of Wind Turbine Manabendra M. De Siemens 5 January 7, 2007 00:42
