Periodic Condition for Particle Tracking in DPM
Old   April 15, 2013, 19:06
Default Periodic Condition for Particle Tracking in DPM
vagaikwa is on a distinguished road
Can anyone tell me how can i make my particles periodic? It means if my particle leaves the outlet it should again enter from the inlet with the same data attributes which it had while leaving the channel. Im using Discrete Phase Modelling. Thanks.
Varad.
vagaikwa is offline   Reply With Quote
Old   April 15, 2013, 22:44
I guess once you give the periodic boundary condition for the single phase and then introduce particles it automatically does that, that is it re-enters through the inlet once it is out from the outlet.
Old   May 22, 2017, 05:14
Walid Abou Hweij
walid abou hweij is on a distinguished road
Dear Mr. vagaikwa,
I have a similar problem where I need to determine the number of repeats of the periodic zones, that is I need the zone of the pipe which is 40 mm in length to be repeated 4 times. It is to be noted that I don't need just to display that but to take this number of repetitions while evaluating the flow problem.
Regards,
Walid
walid abou hweij is offline   Reply With Quote
FLUENT Periodic Boundary Condition SOLVED + TUTORIAL Peter023 FLUENT 55 July 11, 2020 07:40
[ICEM] Periodic condition between ICEM and FLUENT Touré ANSYS Meshing & Geometry 0 August 5, 2012 18:00
about the implemention of periodic boundary condition harbinyg Main CFD Forum 5 July 12, 2012 05:30
construct a periodic boundary condition in Gambi? Daniel FLUENT 0 October 17, 2006 11:28
translational periodic boundary condition Rola Afify FLUENT 2 September 12, 2006 09:39
