Porous zone
Old   April 14, 2013, 17:07
Default Porous zone
roupcik is on a distinguished road
Hi CFD users! I have one problem. I simulate (in Fluent 14.5 version) the flow of water through the row of paralel tubes. Tubes are simulated as porous zones with different power (source terms) and every tube is divided to 4 parts (down to up). I defined walls between tubes - with no heat flux, so the boundary condition is isotermic. Walls are not divided to 4 parts as tubes. My problem is following: there should be isotermic condition along the whole wall and there is the wall, but in temperature contours, it seems as expansion of flow ("bubble" of different temperature) but only in small areas in points where two porous parts of tube touch to each other. I dont know, if there is some mistake in setting of porous zone placed next to other porous zone, or if i have to divide the wall to 4 parts in a same case as the tube is divided, or where is the mistake? So do you have some similar experiences in defining walls placed between two (or more) porous zones?
Thanks a lot for your recommendations and advices.
roupcik is offline   Reply With Quote
FLUENT porous zone inputs eishinsnsayshin FLUENT 19 April 17, 2020 05:40
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 05:10
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
