April 14, 2013, 13:01 |
turbulent viscosity limited
mad kash
Rep Power: 13 |
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2....5 cells;
I model a simple wind tunnel that a cone test as sample in this wind tunnel. the flow is air and model prepare in 3D. up stream and down stream checked and territory is acceptable. wind velocity is about 2-4 m/s. and turbolant model is k-w sst. problem is this message in every iteration after about 50-60 iterate.after this solution didnt converge never and residual goes up or has linear motion. in all solution Under relaxation factor for Turbulent Viscosity is 0.6. Please help in this matter. i have not time... |
April 14, 2013, 13:06 |
Khalid Baker
Rep Power: 17 |
This may due to bad mesh quality you need to examine your mesh quality in Gambit see Gambit help for more information about examining quality.
April 14, 2013, 16:15 |
mad kash
Rep Power: 13 |
hi dear Kbaker;
thanks for reply, it was checked in Fluent too and report is: Orthogonal Quality ranges from 0 to 1, where values close to 0 correspond to low quality. Minimum Orthogonal Quality = 4.66412e-01 Maximum Aspect Ratio = 1.71025e+01 as my previous case, its not bad quality. thanks again Please guide me in new |
April 15, 2013, 04:00 |
Paritosh Vasava
Rep Power: 23 |
You can plot the turbulent viscosity, find the area of problem and modify mesh in that region. You may also use adaptive mesh.
April 15, 2013, 05:24 |
Philipp
Rep Power: 27 |
By "bad mesh quality" Khalid also means a too coarse mesh. Do as vasava said and check where the error happens. Maybe your grid isn't fine enough there.
The skeleton ran out of shampoo in the shower. |
April 15, 2013, 06:55 |
mad kash
Rep Power: 13 |
thanks all guys
will do all your recommendation and share what happen. thanks again |
April 16, 2013, 03:41 |
mad kash
Rep Power: 13 |
thanks Ali. I will. let me to modify the risk area mesh. may be some thing change.
thanks again |
April 17, 2013, 04:01 |
#9 |
Khalid Baker
Rep Power: 17 |
In addition to what guys mentioned I add this If you sure your mesh is good try to select smaller time step (fro example 1e-05 sec or 1e-06 sec) and see is this error still reported or disappear? if it disappear try to increase the time step gradually but not jump to higher one selecting of proper time step is very critical and important to let solution converge. And If you solve steady state case try to change solution methods for simple or reduce the under-relaxation factors. Hope this solved what you need.
April 17, 2013, 05:14 |
#10 |
mad kash
Rep Power: 13 |
hi Khalid Baker,
the quality of mesh is good but i'm not sure about size. With one test, in larger cells the problem is growing. and about smaller, the machine capacity is the problem (with size 1 of meshing, it will be 24000000 meshes). did you mean changing the type of case from steady to transient? and then change the time step (in time dependence box) realy thank you thanks |
April 17, 2013, 07:04 |
#11 | |
Khalid Baker
Rep Power: 17 |
No I not mean transforming case from steady to unsteady its your decision about the case type reference to what you think about it. I mentioned the last suggestions for you for both steady and unsteady cases and let the choice for you about the modifications in your case.
April 17, 2013, 07:36 |
#12 |
Paritosh Vasava
Rep Power: 23 |
There is an option in Fluent called 'Mark Poor Elements'. You can look for this topic in fluent help. Although there is no guarantee that the mesh will improve significantly but it will certainly pin-point the problem area.
I am not sure about this but the command 'mesh → repair-improve → report-poor-elements' will some how mark the poor elements. There are some commands in fluent that can improve mesh but I dont remember them now. Look for them. It might do the trick for you. |
April 22, 2013, 07:05 |
#13 |
mad kash
Rep Power: 13 |
hi again;
thanks Vasava and Baker. your suggestions helped me and i improved meshes. i decrease mesh size and the problem with viscosity ratio till (850th iteration)already its happened in 50-80th Iteration. but the problem is why solution didnt converge. the continuity does not decrease more than 5e-2 and after that the solution move horizontally without any convergence or divergence. and some times continuty comes up!! help me please thanks |
April 23, 2013, 09:29 |
#14 |
James Willie
Rep Power: 17 |
In case you try the recommendations above, especially with regards to using a fine mesh and you still get the same problem then you can try to increase the turbulent viscosity under limit and see if that would help you. Jimmy
April 23, 2013, 09:40 |
#15 |
mad kash
Rep Power: 13 |
you mean Limits tap in Control menu?
thanks mad |
April 23, 2013, 11:07 |
#16 |
James Willie
Rep Power: 17 |
Yes, but another thing which i hope u have tried is to play with the under relaxation factors? I would usually reduce them to 0.1 for critical flow variables and then increase them gradually till the problem is resolved. That may also help.Jimmy
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 07:15 |
turbulent viscosity limited to viscosity ratio | Alex_B | FLUENT | 16 | September 12, 2012 14:17 |
Too low temperature at combustor outlet | romekr | FLUENT | 2 | February 6, 2012 11:02 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 07:13 |
