2D case with steady solver problems
Old   April 14, 2013, 10:31
Default 2D case with steady solver problems
Paulina
p_kmb is on a distinguished road
Dear all,
I struggle with my case for a bit, and I need your help.
I am using Fluent steady solver for turbulent incompressible flow. I want to make comparison between flow over rectangular and rectangular with cylinders (within one domain), therefore I use triangle mesh.
The wind speed at velocity inlet is 10m/s, Iu=10% and the turbulence Length scale I calculated is L= 0.133. Other boundary conditions are symmetry and outflow. The walls of the domain are at least 10 times from the model.
I tried to used simple and coupled solution methods. First simple and default orders, then I switched to coupled second order. Second computations with coupled second from the beginning.
I cannot get convergence, my residuals oscillate. Is this because transient nature of flow? Should I use transient solver? If yes, how can I compare the results?
Paulina
p_kmb is offline   Reply With Quote
Old   April 14, 2013, 10:38
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Please post some pics of your model and mesh. Why you are not using Hexa?
Far is offline   Reply With Quote
Old   April 14, 2013, 11:20
Paulina
Thank you for quick replay.
There are two reasons I don't use hexa mesh. I try to simulate flow over rectangular and cylinders in one domain and I have four different angles of the wind attack. Therefore I created a circle with my model and I append it to the domain in Fluent, so the mesh is not changed, only the circle rotates.
My mesh have 457002 cells and Minimum Orthogonal Quality = 7.29122e-01
Maximum Aspect Ratio = 4.42918e+00.
I tried to use different mesh, hybrid, with boundary layer, different size. But I got some fluent sweep error using them. And I have to admit I almost like the results I got from computations on actual grid, if only it didn't behave like transient for steady solver.
If there is a mistake in my way of thinking from the beginning, please let me know.
I have problem with max file size that could be attached...
Old   April 14, 2013, 12:06
Far
Sijal
I am pretty sure that your domain is too short. Make it 15 lengths upstream and 25-30 lengths downstream.
Old   April 14, 2013, 14:20
Paulina
I changed the domain as you suggested.
I still run calculations, but after 2300i (1000 simple then coupled 2-nd order) I can say that results oscillate again.
Simulations are made with k-e RNG model.
Any idea what should I do? Change the mesh?
Old   April 14, 2013, 17:55
Far
Sijal
Yes the flow is transient. To compare results you have to take into consideration time-average values of variables at particular location.
Old   April 14, 2013, 18:32
Paulina
Thank you.
Unfortunately I know nothing about transient solver.
How can I get time averaged results? From post processing? How many time steps do I need too make a good average? I'll appreciate any info or tutorials.
One more question. When I change the angle of my model, should I also change turbulence length scale (especially with 90 degrees)? I have doubts if I can compare results with different turbulence length scale.
Can I even use the Fluent Manual equation L=0.4*d for external flows? Integral scale of turbulence for wind is ~100m. The result from the Fluent equation is 0.054m.
2d flow, oscillations, solver options
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 07:35
Is steady state solver grid dependent? mmkr825 OpenFOAM 4 March 22, 2013 13:46
Help: CURRENT_TIMESTEP with FLUENT Steady Solver lihuang Fluent UDF and Scheme Programming 2 March 14, 2013 10:25
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
TUI Transient solver to Steady solver mbell10 FLUENT 1 February 2, 2011 09:53
