How to define a fixed velocity for a given mass flow rate on inlet
Old   April 12, 2013, 03:13
Exclamation How to define a fixed velocity for a given mass flow rate on inlet
Qasim Ali
mqasimali is on a distinguished road
Send a message via Yahoo to mqasimali Send a message via Skype™ to mqasimali
hello,
I am simulating a turbulent flow through a vertical channel with some sort of blockage.
its mass flow rate at inlet is 0.3 kg/s
using mass flow rate = density* area* velocity for inlet i come up inlet velocity as 2.4 m/s
that is reasonable...
but when i step into fluent, i defined the mass flow rate exactly in vertical channel but inlet velocity is jumped up to 80m/s
how to fix this inlet velocity???
i am only defining the mass flow rate, rest i initialize the value from inlet that takes velocity in 80s, even if i keep it down but fianl form after iteration makes it deviate again.
in other words i want fixed velocity at inlet. help me out.
thankyou
mqasimali is offline   Reply With Quote
Old   April 12, 2013, 03:17
ghost82's Avatar
Rick
ghost82 will become famous soon enough
I think your solution is not converged, that's why your velocity field and other variables are wrong.
Daniele
ghost82 is offline   Reply With Quote
Old   April 12, 2013, 18:24
Qasim Ali
i tried different grids to check their independence, all yielded results in same pattern and it stops the results with comment solution is converged
mass flow rate
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 03:07
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 11:09
How to define mass flow rate using UDF? SAMUEL FLUENT 3 December 25, 2004 01:36
How to define mass flow rate using UDF? SAMUEL FLUENT 0 December 16, 2004 03:55
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
