Different between species and UDS?
Old   April 5, 2013, 11:09
Default Different between species and UDS?
cinwendy is on a distinguished road
I want to simulate some tracer/reactant. I used species transport and got some results. Now I am looking at UDS, and I get different results. I have a species with properties of pure water (by specifying mass fraction) and a UDS also with diffusivity of water (by specifying value at boundary). These two looks the same for me, so I was expecting I will get the same results. How are they differ from each other?
Thanks a lot in advance!
cinwendy is offline   Reply With Quote
Old   April 6, 2013, 10:06
SSL
msaeedsadeghi is on a distinguished road
both species transport equations and UDS are scalars. You should get the same result if you have setted it correctly. I have worked with UDS and UDF so much. It's easy.
msaeedsadeghi is offline   Reply With Quote
Old   April 7, 2013, 05:57
Hi Saeed,
Thank you. I was comparing the distribution of mass fraction of a mixture with properties of water to that of using UDS. The mixture contain 2 liquid water species, just to differentiate from one another. So I set mass fraction at BCs and apply source term in cell zone. On the other hand, I defined a UDS, set the diffusivity (the only thing I was allow to set in UDS) to the the same as that in the mixture properties. The UDS also has the same "value" (not sure why, but "flux" didn't work well) at BCs and source term in cell zone.
One thing for sure is that pressure outlet setting give me erroneous results. Because setting species mass fraction to 0 and setting UDS value to 0 seems different. I am not sure how to amend this.
Anything else that I missed out?
Old   April 9, 2013, 03:43
Can anyone tell me which UDF or setting I should use for pressure outlet BC for a scalar which the value and flux are not known? At the BC, FLUENT expect return viod, I can't use DEFINE_SOURCE. But I am clueless looking at the manual...
Old   April 9, 2013, 05:18
Astio Lamar
asal is on a distinguished road
Hi!
If your flow exposed by the gravity force, which means that if you have buoyancy, then you may have different results from species and UDS.
asal is offline   Reply With Quote
Old   April 9, 2013, 10:34
In order to simplify for easier comparison, that my UDS behave exactly like pure liquid water, I didn't use gravity for both cases.
I was able to get similar trend when using UDS, compared to that of using species transport. But the different was big (~1% far away from wall, and totally off at the wall).
What should I do?
UDS Species calculation is DIFFERENT! Davis FLUENT 0 June 28, 2007 12:44
Define Electron as a UDS or Species Ilati FLUENT 0 April 25, 2007 04:52
Species transport eqn using UDS Vishal FLUENT 0 March 22, 2006 00:00
Calculate net species/ UDS flux PK57 FLUENT 3 August 4, 2004 10:59
Multiple species and UDS source terms Ale FLUENT 2 September 9, 2002 04:45
