Dynamic Meshing 2D whole domain translation
Old   April 5, 2013, 10:56
Default Dynamic Meshing 2D whole domain translation
Nate Wagenhoffer
newtbeard is on a distinguished road
I am trying to mesh a solid falling through a fluid. This will be solved via fluent (6DOF problem). My problem is that the entire domain translates instead of just the solid that should be falling through the fluid medium (but at least the velocity values seem to be correct). I have stripped this down to as simple a problem that I could.
It's a 2D geometry, with constant temperature. For this initial case all I want to be able to see is how the solid will move through out the liquid if small perturbations attack it from various angles.
I feel that this is a meshing problem, as I have been able to run through several different tutorials with no problems. I have the fluid set up as triangulation and then a group of quads around the solid.
the mesh I attached is obviously wrong, but it shows the three distinct zones.
Let me know if you can help.
newtbeard is offline   Reply With Quote
dynamic mesh
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
[ICEM] Dynamic Meshing of a 2D Airfoil Anonymized_JL1 ANSYS Meshing & Geometry 65 October 11, 2012 05:22
How to set domain translation and rotation in CFX ricardo.halfeld CFX 7 September 8, 2009 19:22
Fluent Dynamic Meshing Vimal FLUENT 0 August 29, 2007 14:11
Dynamic Meshing Philip FLUENT 0 February 2, 2006 17:06
