Adaptive time stepping problem for periodic problem |
sam daysley
Rep Power: 13 ![]() |
Hi
i'm currently simulating a VAWT turbine in ANSYS, using the sliding mesh approach. However, initially the turbine spins the inner domain creating a lot of disturbance in the results and takes roughly 3-4 seconds to reach a quasi-steady solution. i've been trying to use adaptive time stepping to run the first say 4 time steps at a larger step size so i can pass through this zone and reach the periodic time faster. however, when i change the settings and run the simulations, it starts to diverge and is unable to solve the porblem so i have to revert back to fixed time stepping which takes too long. is anyone familiar with how to solve this? all help is greatly appreciated! thanks in advance sam p.s. this is the set up for the adaptive time steps i tried trunc. error - 0.01 end time - 10s min step size - 0.005s max step size 0.5 min step change factor 0.005 max change factor - 0.5 fixed time steps - 4 i hoped this would run 4 time steps at 0.5s then decrease to 0.005 when it hopefully reaches a periodic solution? |
sam daysley
Anyone have any ideas on adaptive time stepping? anything's a help
OJ
Rep Power: 20 ![]() |
Try with reduced minimum timestep, say 0.001, or smaller if you still see the divergence.
OJ |
sam daysley
Thanks again OJ, i'll try that tonight and let you know if it works
sam daysley
OJ,
unfortunately reducing the time step size did not work, it ran for a few time steps and then divergence was detected. and a floating point exception error was produced?? I've attached a screen shot of the error. i also tried increasing the order of the solution methods thinking that would help as the error mentioned momentum divergence but to no avail. thanks again |
Colin Fiola
Rep Power: 14 ![]() |
Maybe check your viscosity ratios and such in your BCs?
sam daysley
Thanks for the input Colin and Far,
After looking more into turbulent viscosity on this forum i altered my ratio, hydraulic diameter to 5m (the width of my domain) and turbulent intensity to 5%. i also totally remeshed my domain instead of using a random tri-mesh i mapped the rectangular area and then used a random tri-mesh for the rotor domain due to its complexity. This seemed to work and i have not been stopped with any floating point or turbulent viscosity ratio errors yet. Thanks again for both your help it was much appreciated. |
adaptive-time stepping, fluent 13, sliding mesh, timesteps, vawt |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Adaptive time stepping | Simon | Main CFD Forum | 9 | February 7, 2008 11:41 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
