Problem on Input heat into a Particle with DPM
Old   April 5, 2013, 00:39
Default Problem on Input heat into a Particle with DPM
npl
npl is on a distinguished road
I want to apply a thermal load on the particles travelling through air. Should i use function of Define_DPM_Law.
However when i change the temperature of particle by command P_T(p) in Define_DPM_Law, the temperatue of particle still is the same with that of air.
What should i do?
npl is offline   Reply With Quote
Old   April 6, 2013, 10:09
SSL
msaeedsadeghi is on a distinguished road
You should use:
DEFINE_DPM_HEAT_MASS
msaeedsadeghi is offline   Reply With Quote
Old   April 6, 2013, 23:47
npl
*DEFINE_DPM_HEAT_MASS can not be applied in the inert particle. My problem is about the heating process of solid particle.
DPM problem - wrong particle temperature Johannes FLUENT 1 December 1, 2014 13:48
DPM Output Problem (Again...) DLINSA Fluent UDF and Scheme Programming 1 March 16, 2012 01:45
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari Fluent UDF and Scheme Programming 0 August 19, 2010 04:09
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari FLUENT 0 August 19, 2010 04:01
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
