Wrong Result?
Old   April 4, 2013, 11:27
OJ
oj.bulmer will become famous soon enough
Spincfd,
Have you checked which window the data should appear in? You should find it in monitors window. Make sure you choose the same window as specified in the monitors tab and "Print to console" is activated. Otherwise you may have the blank window.
OJ
oj.bulmer is offline   Reply With Quote
Old   April 4, 2013, 19:14
spincfd is on a distinguished road
Originally Posted by Bollonga View Post
These pictures are from the run calculation menu?
The first one looks like the steady simulation iterations panel, no timesteps in a steady simulation.
The sencond one is to set up the transient simulation iterations. You can choose how many iterations per timestep, how many timesteps and the size of the timesteps.
This is to set the iterations of the solver, nothing to do with animation.
How to do the transient iteration?
spincfd is offline   Reply With Quote
Old   April 4, 2013, 23:52
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Go to general tap (on left side) and choose transient. Now go to calculate panel and give the time step size and total time steps.
Far is offline   Reply With Quote
Old   April 5, 2013, 00:06
This is the video of the blank screen problem.
http://speedy.sh/7mpVt/Video.zip
Old   April 5, 2013, 01:53
I am sorry as the video resolution is too small and can not be viewed.
I am trying to upload better video resolution.
Old   April 5, 2013, 02:00
Originally Posted by oj.bulmer View Post
Spincfd,
OJ
It doesn't looks like Fluent 6.2.16.
Also, it looks like you are using a Mac.
Compare yours with mine.
Old   April 5, 2013, 02:03
Go to the general tap?
Perhaps tab.
There is no general tab in Fluent 6.2.16.
Old   April 5, 2013, 05:27
Francisco
Bollonga is on a distinguished road
Perhaps tab.
Define - Model - Solver
Where you see Time choose unsteady (unsteady - transient means the same)
http://cdlab2.fluid.tuwien.ac.at/LEH.../tg/node57.htm
Spincfd,
OJ
You can find this in Solve - Monitors - residuals
See step 4 here:
http://cdlab2.fluid.tuwien.ac.at/LEH.../tg/node61.htm
On the top right corner, in Plotting square you can choose the windows where to show your monitors.
Be sure you are recording each frame of your animation, you will have a file for each one. If you don't have this you might have not set the animation properly and that why you can't watch it.
Fluent 6.3 User Guide: http://cdlab2.fluid.tuwien.ac.at/LEH...g/main_pre.htm
Fluent 6.3 Tutorial guide: http://cdlab2.fluid.tuwien.ac.at/LEH...g/main_pre.htm
Bollonga is offline   Reply With Quote
Old   April 5, 2013, 06:14
Why I should choose the unsteady if I want the steady and laminar flow?
What I understand is, you tell me to check/choose the unsteady option if I want to iterate as a time step instead of number of iteration, am I right?
See step 4 here:
I don't do this step before the blank problem appears but the display shows the animation very good.
I have a laptop, the blank display also happen in my laptop.
I can see all of the files associated with the animation for every frames.
A lot of files.
Old   April 5, 2013, 06:28
Francisco
Yes.
A lot of files.
Can you open any of this files to check if they're okay?
Old   April 5, 2013, 07:43
A lot of files.
There are two types of file.
.hmf and .ppm
What software to open them?
And how do I know if them is okay or not?
Old   April 5, 2013, 08:12
Francisco
.hmf and .ppm
ppm are portable pixel map. I've opened them with photoshop, but I'm sure there are other softwares.
With correct I mean if there's something on those images or they're blank.
Old   April 5, 2013, 12:00
I open one of them, the .ppm file, in the Adobe Photoshop and you are absolutely correct.
The image shows blank.
CFX calculates wrong secondary flows feizaghaee CFX 15 April 9, 2018 04:01
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 11:27
dimension error in result of volPointInterpolate(p) mgolbs OpenFOAM Pre-Processing 2 January 21, 2010 11:28
LES result harrislcy FLUENT 1 December 28, 2009 07:29
BuoyantBoussinesqSimpleFoam and axial-symmetric results wrong mass flow Thomas Baumann OpenFOAM 6 December 21, 2009 11:31
