User Defined Scalar (UDS) For Electric Potential |
March 30, 2013, 07:22 |
A-A Azarafza
Rep Power: 14 |
Hello Folks
I want to define two electric and protonic potentials inside a fuel cell using UDS. Here's the problem: when I define electric field, then it's required to define UDS diffusion coefficient which is in fact, electrical conductivity and has a dimension just (1/ohm.m) and it's different from UDS diffusivity coefficient exist in material panel which is (kg/m.s). How can handle this problem? Furthermore, in material panel there are also other parameters such as density or viscosity and etc. what should I do with them for UDS? Should I actually use material panel for this purpose? Please give me some advice. Thank you in advance.
Regard yours Last edited by A CFD free user; March 30, 2013 at 14:08. |
How to calculate electrical potential with UDS? | seagullor | FLUENT | 3 | August 25, 2024 20:39 |
dieselFoam problem!! trying to introduce a new heat transfer model | vivek070176 | OpenFOAM Programming & Development | 10 | December 23, 2014 23:48 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
Define bounds of a user defined scalar | Philipp_Sch | Fluent UDF and Scheme Programming | 0 | October 11, 2010 08:47 |
User Defined Scalar (UDS) question (units) | D | FLUENT | 0 | March 1, 2006 20:04 |
