Double precision case open in single precision solver.
Old   March 26, 2013, 06:04
Default Double precision case open in single precision solver.
cinwendy is on a distinguished road
Has anyone encountered the said issue? I run some calculation in double precision, get some results and then close FLUENT and WB. Sometime later, I want to continue calculation from the same case and data. WB asked me to "edit" from the "resultd' cell as if I "edit" from "setup" cell the calculated data will be erased. The preference in WB is set such that FLUENT is double precision by default. But whenever I open FLUENT from "results" cell, it is always single precision.
How to handle this? Thanks!
cinwendy is offline   Reply With Quote
Old   March 26, 2013, 08:27
OJ
oj.bulmer will become famous soon enough
I think you can't open FLUENT from "Results" tab. You need to open it using "Solution" tab. The Workbench preferences will be different for different instances of Fluent simulation. You need to make sure the preferences for every FLUENT simulation is double precision.
OJ
oj.bulmer is offline   Reply With Quote
Old   March 26, 2013, 12:03
Thanks OJ.
Sorry, my mistake, I meant to say "solution" tab. "Results" tab is CFD Post. The preference for FLUENT is already be set to double precision, besides at the first time starting FLUENT from WB I have a chance to make sure that. The properties of 'solution' is single precision, fixed. This tab is 'generated' while I am running calculation in FLUENT, don't think I can do anything with it.
Any way to handle this? Or must I calculate everything (from the beginning to the end) in a single FLUENT session? Or must I copy the latest case and data file and then import them into a double precision FLUENT elsewhere?
I am quite concern about this as if I continue on a single precision solver, the precision might get affected.
Thanks!
Old   March 26, 2013, 12:21
OJ
How are you sure the WB preferences are always fixed? When you right click on Solution tab in WB, select Properties and look towards right hand pane, what do you see as the default preferences? Is it double or single?
OJ
Old   March 26, 2013, 12:57
Hi OJ,
1, In WB, tools-> option->FLUENT tab, I make sure by default it is in double precision.
2, When opening FLUENT for the first time, say, after I get the mesh done, I can make sure that it is double precision in the launcher.
3, Properties for setup is double, but it seems can be changed (there is a downward selection arrow on the right). But the properties for solution is single, fixed.
So basically I just don't know why when I want to continue calculate a double precision case, the solver itself become single precision...?
Old   March 26, 2013, 14:35
OJ
Right click on Solution >> Properties
At right hand pane, uncheck "Use Setup Launcher Settings"
Now the Precision option will be editable
Set Double Precision.
Does this work?
OJ
Old   March 27, 2013, 04:19
Yeah! It works! Thank you very much, OJ!
Single or double precision Jonas Larsson Main CFD Forum 16 June 20, 2017 07:53
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 12:00
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Need help to open an OpenFoam case with Paraviw aaurouss OpenFOAM 2 July 6, 2009 14:18
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
