March 21, 2013, 12:34 |
error in C_T() macro....
Rep Power: 14 |
hi ..
In my UDF I need to defien a source term in a porous zone...for definig this source term i need the vel, temp, etc at cells prior to this porous zone (cells within a certain distance limit) .. for this I've written an udf ( using define_on_demand macro)which makes a list of all such cells - their x,y coordinates, cell id ,thread id (these are the cells which are of my interest and which lie prior to the porous zone ..) then in the porous zone "DEFINE_SOURCE" macro I read this text file 1line=1cell at at time .. i then convert the T_id(integer to the pointer using Look_up_thread and pass this as variable to C_T as follows: T_por_in_calc1=T_por_in_calc1+C_T(c_id,t_pointer); I get and error here "segmentation violation" .. complied properly bu while running i get this error ... .. Is passing the pointers the way i did to C-T ok 9escp because it the define source is in a thread other than Im using the thread for C_T .. is any other way out? |
March 22, 2013, 09:03 |
Paritosh Vasava
Rep Power: 22 |
I think that the error is not with C_T. Can you post your UDF?
March 22, 2013, 09:14 |
Paritosh Vasava
Rep Power: 22 |
Can you try this and see if it works.
1. Initialize and run simulation for few iterations (e.g. 5) WITHOUT hooking the UDF. 2. Hook the UDF and then run simulation. |
March 22, 2013, 11:24 |
#4 | |
Rep Power: 14 |
Hi thanks .. its working now . Its was a v silly mistake .. I had forgotten to set the energy equation on in models panel . I was actually proceeding from simpler non-thermal case to thermal variation case.. and in the "rut" forgot to turn it on . its working now |
August 1, 2021, 09:33 |
tyehuo
Rep Power: 6 |
aaaaaaaaaaa!!! I made the same stupid mistake. fuck /
StarCCM+ Command line options and Macro execution | isidp | STAR-CCM+ | 8 | January 29, 2013 05:00 |
Run macro for Multiple file | furione | STAR-CCM+ | 6 | November 28, 2011 14:54 |
Macro Trouble -Winows Explorer Crashes with Macro | Martin Castillo | FLUENT | 1 | July 25, 2007 04:18 |
Macro problem | cfddummy | Siemens | 1 | April 9, 2007 12:37 |
Call a macro from a macro | Flav | Siemens | 2 | July 1, 2004 05:42 |
