Porous jump problem (Really bad problem)
Old   March 17, 2013, 09:21
Default Porous jump problem (Really bad problem)
Recep Kaya
recepky is on a distinguished road
I have a very bad problem, I have 1 inlet, 1 outlet, 1 porous jump(membrane), and one outlet after porous jump that is permeate out.
Inlet velocity: 0.65m/sec (actually 300L/hr flowrate converted to velocity inlet divided by surface area of the inlet pipe) Pressure Gauge: 150000 Pa = 1.5 Bar
Pressure outlet - 1: 150000 Pa
Pressure outlet - 2 (just after porous jump): 0 Pa
Face Permeability: 1.18e-16 m2
Thickness: 0.0002 m
C2:0 (I dont exactly know inertial loss is necessary or not, because flow through 0.0002m thin membrane how can I measure this coeff.)
Solution does not converging with these values, if I change the Face Perm. to 1.18e-12, then problem converges, why?
recepky is offline   Reply With Quote
Problem with rhoPorousMRFSimpleFoam and how to define porous media Amit Mathur OpenFOAM 6 July 18, 2013 07:57
Equivalent porous jump condition svp FLUENT 1 September 13, 2012 14:51
Porous jump Dany Rincon FLUENT 0 March 27, 2007 14:07
problem about droplets in porous cck Siemens 0 August 6, 2005 01:48
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
